Is This A Good Enough Welder To Use For The Mini ?
Posted 05 October 2008 - 11:23 AM
Posted 05 October 2008 - 11:24 AM
Im looking at getting this welder sometiem soon i was just wondering would it do to learn and use to weld the panels on the mini ? thanks
i am wondering the same thing please some one help us both out please!!
Edited by not for sale sorry, 05 October 2008 - 11:25 AM.
Posted 05 October 2008 - 11:32 AM
Posted 05 October 2008 - 12:18 PM
Posted 05 October 2008 - 12:36 PM
imo 60 amps is far too high a minimum current, and the complete lack of adjustability will make welding thinner sheets (mini bodywork is thin, often less than 1mm sheet)difficult.
I would recommend looking for something that gives a lower minimum. 40, or preferably 30 amps would be good. You are unlikely to need more than 100 amps max for minis and general fabrication.
This one looks a better bet if you are set on No-Gas welders....
http://www.machinema...sin-mig-welders
They stock several normal gas mig units...
http://www.machinema...diy-mig-welders
buit most are closer to £200 - £250
Have a look on www.mig-welding.co.uk for buying info and guides.
Posted 05 October 2008 - 12:54 PM
Very good welder but it depends on your price range really. You get the best of both worlds too !
Posted 05 October 2008 - 06:55 PM
Hmmm, "range 60 - 90 amps" it says. if you look at the picture, its just got a high or low switch, so the power is either 60 or 90 amps!
He's right, however I would suggest that the min current would be 30 especially for a novice.
Posted 05 October 2008 - 10:51 PM
Posted 06 October 2008 - 04:03 AM
as said by some one penetration is the key dosent matter how the weld looks as long as it penetrated
michael
Posted 06 October 2008 - 08:34 PM
Posted 06 October 2008 - 08:36 PM
