Heater Matrix Pipes Leaking
Posted 18 November 2008 - 12:47 PM
1992:
So I now have a non-leaky heater matrix, a working blower, heat coming out of the vents and demisting my windows (yay!) and an open plastic container to catch the drips which vary in rate below the heater matrix pipes. I have screwed the screws in tight as I can, put two restraining clips round the tubes, and yet still there is red liquid oozing from somewhere around the junction. It sounds like such an odd question but am I missing something? Am I meant to use a gel or a is there meant to be something rubber below the securing plates? If you think maybe something isn't tight enough tell me how I can make it tight enough please!
Tiffer
Posted 18 November 2008 - 12:51 PM
Posted 18 November 2008 - 12:52 PM
Do you have the heater matrix with the two alloy stubs pointing upwards?
yes sorry I meant to say that.
Posted 18 November 2008 - 01:38 PM
Posted 20 November 2008 - 08:39 AM
Posted 20 November 2008 - 09:15 AM
If superglue has solved your problem great (until you need to replace the matrix again and get the stubs back
Posted 20 November 2008 - 09:18 AM
There should be a rubber o ring between around the bottom of each stub, just below the raised shoulder that the securing plate bears on.
If superglue has solved your problem great (until you need to replace the matrix again and get the stubs back)
I'm hoping that I will never have to replace the matrix again - please dear God! Lighting doesn't strike twice I hope!
The rubber rings were there, they were obviously just being a bit *rubbish*.
