Body Work Filler
Posted 19 November 2008 - 05:24 PM
cheers T.Crown
Posted 19 November 2008 - 05:58 PM
hi folks can anyone recommend a filler that i can skim the whole shell with ? preferably a dark colour ,
cheers T.Crown
why?
Posted 19 November 2008 - 06:12 PM
cheers T.Crown
why?
why what ?
covering the whole car then rubbing it all off leaving the filler in all the low parts and imperfections in panels . and a dark colour so the low bits once filled will be clearly visable.
Posted 19 November 2008 - 06:19 PM
Really no need to fill the whole car, if you do, it will be a whole load wobblier than if you'd just filled the damaged/ bent areas.
Most of the decent filler is made by U-POL, we use Upol easy sand stuff, its alrite but can be a little pinholey at times but is pretty cheap.
Posted 19 November 2008 - 06:23 PM
Posted 20 November 2008 - 12:05 PM
Posted 20 November 2008 - 02:38 PM
Spray filler my man. in grey thats what you need.
I concur,.. Also goes by the name of Spray putty,.. basically a very high build primer.
Posted 26 November 2008 - 08:16 PM
