Hvlp Spray Guns
Posted 19 November 2008 - 09:22 PM
ive been ebaying again trying o find a compressor big egnough to spray a car but my god they are expensive
my question is can i use a HVLP gun with a smaller compressor or does it have to be a turbine compressor
if i can use it on a smaller compressor what size is best
cheers again for all your help
andy
Posted 19 November 2008 - 09:47 PM
Hi all.
andy
you need to know thw CFM of the gun and get a compressor which has a higher CFM rate, if you are using an air
respirator then this will also have to be taken into account.
this is mine
this just copes with an hvlp gun and a respirator.
Posted 19 November 2008 - 11:51 PM
Portability: Portable
Power Option: Powered
Item Weight: 150.0 lbs.
General Warranty: 1 year
SCFM Delivery:
SCFM Delivery At 40 psi: 5.6 SCFM
SCFM Delivery At 90 psi: 5.1 SCFM
Tank:
Compressor Tank Capacity: 75 gal.
Maximum Compressor psi: 175 psi
Compressor Tank Pump Style: 2-Stage Oil Free
Compressor Tank Type: Vertical
Motor-Engine:
Amps: 15.0
Horsepower: 1.60 hp
Type: Electric
Cooling Fan: Yes
Cooling Fan Type: Internal
Drive Type: Direct drive
Posted 20 November 2008 - 07:53 PM
and does the HVLP gun give as good a finish as a normal gun
thanks again for your comments
Posted 20 November 2008 - 07:58 PM
very nice
bram
Posted 20 November 2008 - 08:35 PM
why does the compressor tank need to be so big if the cfm on the compressor is larger than the cfm of the HVLP gun
hvlp means - high volume low pressure. more paint with less pressure, lower pressure
reduces overspray = less wasted paint = less pollution.
the compressor needs a higher cfm so it always has more air in than the spray gun can
use, therefore the gun wont run out of air.
basically.
Posted 20 November 2008 - 08:45 PM
thanks
andy
Posted 20 November 2008 - 09:01 PM
But why do you need such a big tank on the compressor could i not use a 12cfm compressor with a 25 litre tank if my spray gun only needed 5cfm to opperate
thanks
andy
the gun draws off the tank, i think a large tank also allows the air
to stabalise, the higher cfm pump keeps the tank full, in an ideal world
the pump should be able to fill the tank and stop while air is being drawn.
Posted 20 November 2008 - 09:30 PM
thats huge not many compressors keep up with that just the turbine sets
Posted 21 November 2008 - 12:32 AM
Posted 02 December 2008 - 09:28 PM
and i only paid £120 for it used 10-20 times to inflate truck tyres (guy advertised it poorly on ebay)
question now is what spray gun should i purchase and what needle sizes should i use for what coat
planning on spraying 2K and have a filtered mask with air feed but battery powered so no loss of flow
idealy try candy apple red
any suggestions
andy
Posted 02 December 2008 - 09:38 PM
right i got sorted with a compressor its a sip workshop 150 litre (and it is huge) 150psi 15cfm which should be plenty
any suggestions
andy
I've got a sata 3000 and its been consistently superb.
Posted 03 December 2008 - 01:30 PM
thanks
andy
Posted 03 December 2008 - 02:28 PM
you have a gun for primer, a cheap one will do here..
a gun for colour...
and a gun for the clear coat...
freaker
Posted 03 December 2008 - 09:01 PM
priming
painting
and clear coating
thanks
