Basically they have one head that has been machined and used and one bare casting as it came out the mould
The heads are 7 seven port but not in the usual way of the inlets at the front and exhaust at the back making them into a crossflow head but all ports are at the rear.
The 3 exhaust ports are in the normal positions and between them the inlets each split into 2 ports so making the 4 inlets which then had inlets which mated upto twin weber carbs but using all 4 barrells, not split webers as on a 5 port head.
Both castings are cast with the speedwell logo by the thermostat housing end
Has anybody any information on these heads at all please?
Photos should be below
Ian
