Twin Hs2 Needles?
4 replies to this topic
#1 087dave
087dave
  • 952 posts
Posted 02 July 2009 - 10:32 PM
Hello all i have a project 998 with a stage1 kit stage 3 head sw5 cam lightened flywheel and twin HS2 carbs
would anybody out there know what type of needles i would need
Thanks in advance!!!!!
#2 bmcecosse
bmcecosse
  • 9,699 posts
Posted 03 July 2009 - 08:00 AM
What needles are in the carbs right now ? They probably won't be far away - try them !
#3 Retro_10s
Retro_10s
    Moderator
  • 10,176 posts
Posted 03 July 2009 - 08:07 AM
What needles are in them already? the needle should have a profile code stamped on it somewhere - usually the top or side of the top....
As bmcecosse says - they're unlikely to be that far off anyway but i would expect them to need a needle richer than standard given the spec of your engine.
#4 jaydee
jaydee
  • 8,565 posts
Posted 03 July 2009 - 09:00 AM
You probably need a custom needle, with sw5 cam have a power figure similar to standard for idle to 3500 rpm, and improved power at mid/high revs. That means that you will need a needle that is richer from section 6.
I'd give a try with GX needles..
#5 087dave
087dave
  • 952 posts
Posted 03 July 2009 - 01:25 PM
Thanks all, i brought the carbs without needles
