You can approach that way with fibreglass doors, as they weigh about 3 kgs instead of the 19kgs of a standard door with winder, glass and so on.
Fitting a standard door with mk1 hinges without reinforcing a panels.. i dont think it will last long..
Speaking as a mechanical engineer by trade I would say the method used in the photos shown in dave21478 post will work ok in the long term, as long as you bolt the reinforcing angle brackets back to the strong original internal hinge mounting areas on the door pillars as shown in his pictures. A couple of gussets across these hinge angle brackets (like the original Mk1 inner panel brackets have) would also help stiffen things up. The Mini Magazine article on this conversion a while back was much more involved with welding and A panel replacement but I'm sure a 'bolt on kit' of reinforcing angle brackets requiring minimal bodywork could easily be developed for this hinge mod. I would also be interested to know the difference in weight of MK1/2 doors to Mk3 on..............apart from the winder mechanism where is the extra weight if any? The Mk3 inner door skin is full of holes and the early metal door pockets are gone.
Edited by mab01uk, 31 December 2009 - 11:58 AM.
