Mpi Wont Start
10 replies to this topic
#1 tyson8t7
tyson8t7
    Just On Tickover
  • 8 posts
Posted 02 September 2010 - 12:00 PM
I own a 1275 MPi mini copper that has deveolped a starting problem. The car was running fine until recently, now when i turn the key to start nothing happens.
I have tried replacing the battery as i have had problems with this before on this car, i have also checked all the fuses. I recently replaced the started motor on the vehcile but it has been running fine with the new one on.
The body work under the windscreen (mainly where the alarm ecu is) has completely rusted away so i think that the alarm ecu has got moisture in it and is therefore knackered.
I'm wonering if anyone has any other ideas as to what the problem could be or if anyone has experienced anything similar, i don't want to replace the ecu's until i have to.
Thanks for any help you can provide.
#2 icklemini
icklemini
  • 2,982 posts
Posted 03 September 2010 - 03:20 PM
is the engine cranking over?
#3 tyson8t7
tyson8t7
    Just On Tickover
  • 8 posts
Posted 03 September 2010 - 03:31 PM
no, nothing happens when i turn the key to start.
the only other time something like this happened i had tripped the inerthia switch which is what has lead me to believe the ecu is fried.
#4 Blatherskite
Blatherskite
  • 501 posts
  • Local Club: Norsk Mini Cooper Club
Posted 03 September 2010 - 05:59 PM
Does anything else electric work - such as lights, radio, etc and do dashboard lights light up even though no cranking? There is a feed from the battery to a connection at the starter motor that then feeds a whole lot of other services, such as the ignition key... poor connection there means variable lack of starting.
#5 icklemini
icklemini
  • 2,982 posts
Posted 03 September 2010 - 06:05 PM
what he said ^^^ is the clock still ticking away?
#6 tyson8t7
tyson8t7
    Just On Tickover
  • 8 posts
Posted 03 September 2010 - 06:18 PM
all the other electrics on the car are working with the exception of the clcok but this has never worked properly in the 2 years i have owned the car.
#7 minimat
minimat
  • 690 posts
  • Local Club: anglian mini club
Posted 03 September 2010 - 07:19 PM
Starter motor connections clean and tight?Battery connections tight?Especially earth to boot floor.
#8 tyson8t7
tyson8t7
    Just On Tickover
  • 8 posts
Posted 03 September 2010 - 08:02 PM
yep.
#9 icklemini
icklemini
  • 2,982 posts
Posted 03 September 2010 - 09:58 PM
immobiliser deactivating?
#10 tyson8t7
tyson8t7
    Just On Tickover
  • 8 posts
Posted 04 September 2010 - 09:26 AM
as far as i can tell it does, the red LED goes out, but i dont know of anything else on the car that could cause this fault.
#11 tyson8t7
tyson8t7
    Just On Tickover
  • 8 posts
Posted 07 September 2010 - 09:33 AM
Problem solved :( . Turns out the soleniod on my 'new' starter motor was faulty.
Thanks to everyone for their help.
