Ok i have done a cadbury base coat then first laquer caot has violet flake in it , a further five coats of laquer was applied (over a year ago ,slow project!) and after curing for six months started to crack with a cobweb type pattern it looks as if it is in only a thin top part of the laquer not very deep .It is a single pack laquer any sugestions on how to repair or make it better without a strip down and re paint would be very very welcome
thanks in advance .
Crazed Final Laquer Coat Help ?
minihaven
, Sep 02 2010 08:53 PM
4 replies to this topic
Posted 02 September 2010 - 08:53 PM
Posted 02 September 2010 - 09:05 PM
Sand it down :/? then buff it.
Posted 02 September 2010 - 10:23 PM
single pack or 1k, sounds like it will all be comming off to me
dave
dave
Posted 02 September 2010 - 10:25 PM
did you buy cheap laquer?
it happened when i did my wheels! in purple ):
Posted 24 September 2010 - 10:43 AM
Hi there,
This sounds very similar to the issues I have had with my project. There are pics on the topic 'clearcoat cracking' if that helps? I used 1K acrylic laquer. Unfortunately you have to sand it back to the bottom of the cracks at least, and if its a problem with the coats below it will all have to be done again. I haven't found the cause yet on mine, its driving me mad! Hope you can get it sorted-good luck!
