Straight Cut Gears And The Law
22 replies to this topic
#1 CooperMad93
CooperMad93
  • 186 posts
  • Local Club: n/a
Posted 01 February 2011 - 11:14 PM
Just out of interest, I find that unmistakable whine from the straight cut gears irrisistable, But what is the law regarding them? Because they're not the quietest of things and whats the likelyhood of being stopped by the police - which could lead to the removal of them? same question relating to exhausts really. If it's got a silencer on can it still be asked to be removed?
#2 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 01 February 2011 - 11:19 PM
Theres no reason why they would stop you for gears and their ignorance, they might end up asking out of curiousity but theres no reason for them to tell you to take them out...alternativly just get an SC box with no SC drops, drop it in 4th when you go near a cop :withstupid: thru drive in 4th your not on the gear set
#3 CooperMad93
CooperMad93
  • 186 posts
  • Local Club: n/a
Posted 01 February 2011 - 11:21 PM
haha thanks for the advice, i'd just argue it's part of the car to them anyway, but they can be a right pain sometimes. I best get saving for them then ;)
#4 charie t
charie t
  • 3,153 posts
Posted 01 February 2011 - 11:23 PM
If the noise is excessive it will fail an mot, let alone get you pulled by the police, i forget the level though.
#5 mini93
mini93
  • 8,615 posts
Posted 01 February 2011 - 11:31 PM
why would it fail an MOT when the testers dont need to take your car for a drive to test it... sc gears will only make any significent noise when moved for a long distance and when revved, so car park driving will be fine
#6 jayzc
jayzc
  • 70 posts
Posted 01 February 2011 - 11:41 PM
not at bingley sunday when the red c plate pulled up. (parked by the doors for sale £5600 iirc) that box sounded mental just parking up
#7 CooperMad93
CooperMad93
  • 186 posts
  • Local Club: n/a
thats what i was just thinking, but relating to the exhaust can you still be failed with a silencer on it, i read somewhere that there is no decibel limit, yet an opposing view said that the exhaust hasnt to be any louder than standard...*shrug* and another view said that it all depends on what the mot tester thinks. straight cut gears would only make the noise when in gear? they wont run the car in gear to test it will they?
#8 gregh55
gregh55
  • 1,706 posts
  • Local Club: naaa
Posted 02 February 2011 - 12:04 AM
the filth round here just pull you for number plates... or the lack of :L
i wouldnt worry about it to be honest, theres hundreds of thousands of minis with straight cuts :withstupid:
#9 danrock101
danrock101
  • 2,479 posts
Posted 02 February 2011 - 02:30 AM
I don't think there's even 100k minis on the road in the uk lol
#10 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 02 February 2011 - 06:19 AM
theres hundreds of thousands of minis with straight cuts ;)
I think that the figure quoted here was that there are currently just over 30,000 minis on UK roads. So therefore I think it's probably more likely to be "hundreds" of minis with straight cuts, as opposed to "hundreds of thousands"!! :withstupid:
#11 Carlos W
Carlos W
  • 10,115 posts
Posted 02 February 2011 - 06:30 AM
Just declare it as a modification to your insurance company! As for the exhaust, you're certainly more likely to be pulled for a noisey exhaust so make sure everything else is in order
#12 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 02 February 2011 - 07:58 AM
Ha-ha... I know the car well.... I don't know why but his has a very distinctive tone...
and back to the op....
No there is nothing in the law/MOT which restricts the level of sound emanating from the transmission, however your exhaust pipe is a different matter, I've had a mini fail an MOT because of the sound level from the pipe... so a straight pipe and a cherry bomb is not a wise idea...
#13 Simon@minispares.com
    Minispares
  • Minispares
  • 3,247 posts
  • Name: Simon Jackson
Posted 02 February 2011 - 08:17 AM
The police can only measure noise levels (generally to test exhausts) when the vehicle is stationary, so they would have no way to measure the gears on the move. As above theough, exhausts can be tested
#14 Darkscamp
Darkscamp
    Drives the 'Thing'
  • 1,475 posts
  • Local Club: Lone Ranger
Posted 02 February 2011 - 08:40 AM
theres hundreds of thousands of minis with straight cuts :)
I think that the figure quoted here was that there are currently just over 30,000 minis on UK roads. So therefore I think it's probably more likely to be "hundreds" of minis with straight cuts, as opposed to "hundreds of thousands"!! ;)
OMG!!! Has no one ever heard of over exaggeration to jokingly get a point across :wub:
Scamp never failed on exhaust, even when it was 128dB :withstupid: Then again the tester did smile when he heard it :(
#15 Asphalt
Asphalt
  • 2,173 posts
Posted 02 February 2011 - 08:50 AM
Oh I would love to be asked to remove my silencer!! :withstupid: ;) :wub:
