Arrgghhh! Help!
9 replies to this topic
#1 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 28 February 2008 - 11:40 AM
:withstupid: :) :cry: :xxx: :xxx: :xxx: :xxx: :xxx:
I've got a timing cover leak from the gasket....
So, I've got everything out of the way to get that off and it's come to undoing the bolts around there. Most of them have come out OK, there's still a couple left that are soaking...
However, there's one little bugger who won't come out >:P
It turns freely but doesn't actually 'unthread' >:lol: It turns and turns but just doesn't undo :xxx:
How utterly screwed, am i? :w00t:
#2 lrostoke
lrostoke
  • 6,923 posts
Posted 28 February 2008 - 11:45 AM
Daft question from me, but its not the one at the front with the nut on it ??.If not only suggestion is to try and get a thin blade screwdriver under the head as you turn, see if that will start it off.
#3 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 28 February 2008 - 11:47 AM
No no ... I've got that off. It's the load of little bolts around the edge :P
I will try the screwdriver thing now.... Thank you
#4 yorkshirechris
yorkshirechris
    11.11.11
  • 3,873 posts
  • Local Club: www.lcmoc.com
Posted 28 February 2008 - 11:49 AM
If it's just turning... that could be why it's leaking :lol: the bolt or more likely the bit where the bolt screws into may be fubar.
Have you had it off before? :P ahem, lol.
#5 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 28 February 2008 - 11:55 AM
YAY! lrostroke.... i love you!!!! :xxx:
thank you!!!!!!! :w00t: :withstupid:
I love my screwdriver too, lol :P
YAY!!! :lol:
WHOOOP WHOOP :)
Chris... I've not had it off with Reggie before, lol :cry:
#6 stickycreambun
stickycreambun
  • 1,865 posts
Posted 28 February 2008 - 12:00 PM
go go JeanBean, nice tip there from Irostroke!
:P
#7 yorkshirechris
yorkshirechris
    11.11.11
  • 3,873 posts
Posted 28 February 2008 - 12:03 PM
Haha well done :lol:
I've had it off Evelyn twice now... the timing chain cover that is :P
#8 GraemeC
GraemeC
  • 7,473 posts
Posted 28 February 2008 - 12:22 PM
Your problem will be it sounds as though there is little thread left in the back plate - which means the bolt won't torque up properly on re-assembly and hence the timing cover will still leak.
#9 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 28 February 2008 - 12:41 PM
I'll see what it does when I re-assemble it.. I'm going to clean up all the bolts before I put them back in, as they're absolutely caked in grime and nastiness! :lol:
Fingers crossed it'll be ok :P
#10 sazal
sazal
  • 3,512 posts
  • Local Club: DCMOC
Posted 28 February 2008 - 12:52 PM
Woop woop!! Go go super Bean! :P
