Operation: Nancy --- Revised
35 replies to this topic
#31 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 26 October 2009 - 08:41 PM
I bet the wife is happy!!
#32 pete
pete
  • 680 posts
Posted 29 November 2009 - 07:03 PM
Started sorting the bodyshell this weekend and realised how much easier it is to work with fibreglass than metal. Had to get the welder out to join panels together :) .
Decided new door steps were needed.
and then got it ready for the new floor that's coming this week
Might be a bit overkill but the owner wants it rust free so replacing whatever is needed. And I know the roof will be dented but it's not a problem as it's going to get a carbon one. Just turning it upside down makes it so much easier.
#33 pete
pete
  • 680 posts
Posted 30 September 2012 - 05:43 PM
Well it's been a while since I updated this. Spent a while fitting new floor to the steel shell and then modifying the frame where it mounts to the front subframe. Didn't like the way it passes through the bulkhead to mount to the top mounts so modified the bulkhead and frame to allow the mounts to be hidden. Then the owner was convinced to buy this
Attached File  image.jpg   57.2K   18 downloads
So stripped everything out of the steel shell to fit into the fibreglass one. Unfortunately the modifications I had done to the frame now don't fit this shell so had to cut them off and start again. Luckily only tack welded so not the end of the world.
Attached File  image.jpg   40.63K   30 downloads
Now got to start again. Fit the frame and then add additional bars to locate the front subframe
Attached File  image.jpg   65.52K   33 downloads
#34 brum,brum,mike
brum,brum,mike
  • Just Joined
  • 554 posts
Posted 30 September 2012 - 06:56 PM
looking good.
I see your old pick up is back on ebay :) very nice car..
#35 Bounce
Bounce
  • 2,197 posts
Posted 27 January 2013 - 04:49 PM
Interesting........
What happened to Nancy?
#36 pete
pete
  • 680 posts
Posted 27 January 2013 - 07:47 PM
Unfortunately nancy is no more. The new floor and a few other bits have been saved for future use.
