Just Can't Find The Problem!
#16
Posted 28 January 2009 - 09:46 PM
#17
Posted 28 January 2009 - 10:06 PM
#18
Posted 28 January 2009 - 10:09 PM
#19
Posted 28 January 2009 - 11:08 PM
This is what i found-
Battery connects to:
ECU via fused link
Alternator
Starter Motor
Ignition
Other (for now bear with me)
We can ignore the link to ECU/Alt/Starter for now.
Ignition connects to-
AUX position: Radio via radio fuse & Clocks/Fan via Fuse 5/6 [light green/white wire]
IGN position: Lights indicators via fuse 1/2 & ECU Clocks via line fuse (7) [white wire]
CRANK position: ECU [white/red wire]
Other connects to- (seems to be a mutil loom connection) [brown wires]
Lighting
Cooling fan via line fuse (5) [purple wire]
Brake Test Switch via line fuse (3) [brown/orange wire]
Brake Test/Lighting/Radio via fuse 3/4 [purple wire]
Indicators/Interior Light via line fuse (1) [pink/orange wire]
Line fuses can be found on Bulkhead, Behind Facia or on slam panel under bonnet lock (in your case roo it may be a good place to start as i assume yours are no longer located here.
The more I think about it the ignition switch may be duff too......
Hope that is of some help.
Edited by Wilson1275, 28 January 2009 - 11:12 PM.
#20
Posted 29 January 2009 - 03:07 PM
As you've checked your supplies and fuses and they seem ok, have you checked your earths yet? Even if you've got 12V to your starter motor, it won't work if the earth strap from the top engine steady to bulkhead isn't working. Assuming the earths on the SPi are same / similar to an MPi, you should have one from the engine steady to the bulkhead and one from the ecu loom to the angle brace in front of the offside tower bolt in the engine bay. Srocket can confirm if that's correct for a late SPi.
Hope you get it sorted soon!
Good luck!
#21
Posted 29 January 2009 - 06:12 PM
Right just spent an hour reading the Haynes
ECU via fused link
Alternator
Starter Motor
Ignition
Lighting
There is no wiring diagram for the SPi with the 24way fuse box and if there is I have not yet found it. What you have to do is use the old SPi wiring diagram for the main part of the loom, they are layed out much the same, little changed, and then just accept the fact that all the fuses are now in the one place and blade type. The haynes manual does describe the 24 way fuse box and the circuits it serves, which is all you really need. Just ignore all the refferences to fusing in the diagrams.
There are no other fuses on the 24way fuse boxed SPi loom, I know this for a fact as I have had the entire loom out of the car when I re built it. There is the 24 way fuse box and the Hypalon Fuse links in the loom itself at the point where they join to the starter motor battery terminal.
#22
Posted 29 January 2009 - 07:24 PM
So now I would just like to say that i have no idea what is wrong with Phoenix - but maybe somewhere in the loom it has broken or melted and mangled itself together.
Edited by Wilson1275, 29 January 2009 - 07:31 PM.
#23
Posted 29 January 2009 - 07:27 PM
(1996) 24 Fuse Engine Bay Fuse box: -
1 -- 15a -- Rear screen heater
2 -- 15a -- Reversing lamps, stop lamps, headlamp dim-dip, indicator relay
3 -- 15a -- Auxiliary cooling fan
4 -- 15a -- Headlamp dim-dip
5 -- 15a -- Heater blower, sunroof where fitted
6 -- 15a -- Wash / wipe
7 -- 20a -- Headlamp flasher, horn, alarm
8 -- 10a -- Tacho, ECU, fuel pump relay, alarm
9 -- 10a -- Stereo, cooling fan relay, auto gear selector lamp
10 -- 10a -- Stereo memory, interior lamp, indicators, hazards, alarm, brake fluid warning
11 -- 10a -- Fuel pump
12 -- 10a -- Starter relay
13 -- 10a -- Side and tail lamps left hand, number plate lamp
14 -- 10a -- Side and tail lamps right hand, instrument lamps
15 -- 10a -- Main beam headlamp left hand
16 -- 10a -- Main beam headlamp right hand & warning lamp
17 -- 10a -- Dip beam headlamp left hand
18 -- 10a -- Dip beam headlamp right hand
19 -- 20a --}
20 -- 15a --}These fuses reserved for overseas spec systems
21 -- 10a --}and accessories (A/C system, front fog lamps etc.)
22 -- 20a --}
23 -- N/C
24 -- 10a -- Rear fog lamp
#24
Posted 29 January 2009 - 07:32 PM
Does anyone know where the loom gets its power - im guessing it is connected to the satrter motor like most minis?
#25
Posted 29 January 2009 - 09:00 PM
I have no power to the systems..... the red line indicates where i feel there is a problem and how the independantly run systems recieve their power (straight off the battery) If i have no power to all the systems and all the fuses are fine there must be a brake some where along that red line.
A goes to power distribution circuit
R goes tp Auxiliary cooling fab circuit
Q goes tp Brake test unit
P goes to Brake test unit
O goes to Dim-dip lighting and horn circuit and Radio circuit
N goes to Direction indicator and hazard circuit and interior light circuit
The alarm/immobilisr will run off this power feed somwhere too.
#26
Posted 29 January 2009 - 09:17 PM
#27
Posted 30 January 2009 - 12:25 AM
Right i finally got round to doing thise...
Again, that drawing is not quite right
There are Hypalon Fuse links in that part of the circuit. Infact, if i remember correctly there are three. And there are two on the alternator circuit on the engine loom.
It should be fairly easy to check these. The Hypalon is a high strength synthetic rubber. When the fuse link blows it does so with such force, its like an explosion. The Hypalon contains this. What this leaves is the outer sheath. If the fuse link can stretch with light force at any point along its length, it has blown.
The links are primaraly there to prevent a fire in the event of a front impact that could damage the wiring, shorting out and blowing these fuse links.
#28
Posted 31 January 2009 - 10:22 AM
I don't want the fusable links to the alternator cause i have power to that. In the diagram the fused links are labled 32. Alternator is labled 39
I want the wire in the opposite direction to it that has no fusable links... does this go to the black relay box? i have power going into it but cannot test if its going out.
I have no power to the live fuses.
its been over a week now aand i still can't find the problem!!
Edited by Roo, 31 January 2009 - 10:29 AM.
#29
Posted 31 January 2009 - 10:53 AM
But it may be that the live to the alternator is ok but it has no live coming back out of it? Just guessing here really. The haynes isn't clear as to how that spurring point works/where it so you can try and follow it, but i would strt at the starter motor and follow the lives to there respective "homes" from there.
That probably makes no sense - sorry
#30
ignition off fuses that are live are:
headlamps
Ignition on fuses that are live are:
headlamps - including fuses for main an dip beam
Heated rear window
tail lights, reversing light
heater blower
Ecu (engine management)
The only fuses that don't have power are to the systems that don't work.
I have power to alternator, starter, relay box and coil (with ignition on)
