I found the problem,
i've pulled all the wiring loom apart. pulled all protected casing off.... halfway up the loom waaas a fuse link!! A broken one!!
Thank you sprocket!!
Where can i get a new one? will halfords do them and are the easy to refit?
Posted 01 February 2009 - 12:45 PM
Posted 01 February 2009 - 12:47 PM
Edited by mini93, 01 February 2009 - 12:48 PM.
Posted 01 February 2009 - 12:51 PM
Edited by bamby, 01 February 2009 - 12:51 PM.
Posted 01 February 2009 - 01:10 PM
Guess what!!
I found the problem,![]()
Thank you sprocket!!![]()
Posted 01 February 2009 - 01:15 PM
Guess what!!
Thats some nice fault finding there Roo(for a bird as well)!!
Congratualations!!
I don't think Halfords will sell the proper jobbie, however I should imagine it would be ok to replace with one of their standard fused links.
You go Roo!!!
Posted 01 February 2009 - 01:18 PM
Posted 01 February 2009 - 02:32 PM
Posted 01 February 2009 - 03:00 PM
Glad you found it Roo - but obviously what i was texting you wasn't the answer you wanted. Fit a normal inline fuse as said abopve and see if it IS the problem.
Posted 01 February 2009 - 03:10 PM
Posted 01 February 2009 - 03:17 PM
Glad it is sorted.
So the wire broke off the terminal on the back of the fuse box is that what your saying? Anywayfor finding it a fixing it - im sure someone on here will be able to point you towards a fuseable link or have one they can give you.
Edited by Roo, 01 February 2009 - 03:19 PM.
Posted 01 February 2009 - 03:19 PM
Posted 01 February 2009 - 03:20 PM
THe fuse hadn't blown, the wire had broken just where the wire comes out of the fuse on the fuse box side of it.
Posted 01 February 2009 - 03:21 PM
Thats really good news! If the link had burned out then the worry would be finding the cause.
Posted 01 February 2009 - 03:24 PM
sorry mis-read your initial post - an inline fuse will be fine Roo and means you can use the car for work tomorrow etc.
*gets coat*
