Mini....with Chain Motor Engine.....
130 replies to this topic
#31 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 20 June 2009 - 05:42 PM
mini sport, mini spares, arc angles, p&l mini, tdk racing and ABS motorsport all do fiberglass front ends :dontgetit:
#32 Retro_10s
Retro_10s
    Moderator
  • 9,933 posts
Posted 20 June 2009 - 06:22 PM
P&L, and Minisport are supplied by anyway - so go direct and cut out the middle man.
I hear great things about TDK value for money. Les at Custom minis also makes some very impressive front ends...
#33 sotiris
sotiris
  • 127 posts
Posted 20 June 2009 - 08:26 PM
Thats an er... interesting design for a rear swinging arm you have there....
You realise that the full load of accelerating the car forward is going to be transmitted through that right???
i do not understand this expression "er... interesting" because i do not know so good English....
this is not finished and not weld
... the final arm will be like (not the same)
that..... and i believe that will hold the load......
i will fill the gap with solid metal and i will weld it like this one.... ......
Edited by sotiris, 20 June 2009 - 08:44 PM.
#34 sotiris
sotiris
  • 127 posts
Posted 20 June 2009 - 08:35 PM
er (ûr)
interj.
Used to express hesitation or uncertainty.
i found it..........lololol
this is the INTERNET for........lolol
on topic ..
now that I showed you the way I will manufacture, which opinion you have ????.....
i want your opinion....
Edited by sotiris, 20 June 2009 - 08:41 PM.
#35 SukiDawg
SukiDawg
  • 304 posts
Posted 21 June 2009 - 10:19 AM
I suppose if you add a gusset on the outer side of the two pipes welded together at a angle it should be OK. I'd never seen the Z cars version before - clearly thats strong enough.
#36 sotiris
sotiris
  • 127 posts
Posted 22 June 2009 - 07:33 AM
tdkracing can not send to greece
#37 Rosslin Racing
Rosslin Racing
  • 2,389 posts
Posted 22 June 2009 - 01:28 PM
what sort are you looking for again? I can send to you from Switzerland.
#38 sotiris
sotiris
  • 127 posts
Posted 22 June 2009 - 02:23 PM
i send mail to ABSmotorsport too, for
(the oem sort)
Round Front End Mini 1 Piece
and
Mini Front End Fitting Kit - 1 Piece
if they do not send to greece i will tell you..... :D
thanks.......
#39 stardude
stardude
  • 2,457 posts
  • Local Club: hilltop mini's
Posted 22 June 2009 - 02:27 PM
if they wont send them, try talking to z-cars as i am sure they have some and i know they send giant boxes all over the world
#40 sotiris
sotiris
  • 127 posts
Posted 23 June 2009 - 07:35 PM
for the plastic front end, to much money for shipping to Greece.... is big box......
180 (the parts) + 200 euro (shipping cost)..... i will think about.... maybe i will find some friends to order something else to filll the box and separate the cost....
@Rosslin if you want and is possible ask about the shipping cost your area for sending to greece..........(but i believe that will be the same....)
here is the rear suspension from z car.....i received today....... >_< :thumbsup: :thumbsup: :P :P
  • Attached File  rear.jpg   114.83K   20 downloads
Edited by sotiris, 23 June 2009 - 08:28 PM.
#41 Yoshi
Yoshi
    Just On Tickover
  • 9 posts
Posted 23 June 2009 - 08:39 PM
Can you give me the basic info on those shocks please ? Travel, compressed/extended length, coil spring rate, brand?
Edited by Yoshi, 23 June 2009 - 08:41 PM.
#42 Yoshi
Yoshi
    Just On Tickover
  • 9 posts
Posted 23 June 2009 - 08:41 PM
today i received the front coil over.......
nice part.......
and also all the rubber seals for the doors and windows.......
tomorrow i will work the mini and i think that we will finish the rear arms.....(difficult part with to much work)
same info for the front shocks too please. Thank ya much....
#43 commander
commander
  • 181 posts
Posted 23 June 2009 - 09:15 PM
http://www.carbonweezel.co.uk/
nice project you have
good luck with it
#44 sotiris
sotiris
  • 127 posts
Posted 24 June 2009 - 06:25 AM
here is the rear suspension from z car.....i received today....... :gimme: :) :o :P :P
i do not know this info.......... :P
i told them which moter i will use (k7 or r1) and they send me this for rear
the front is a kit for mini "gaz...."
i will mesure the travel ect. and i will tell you...
and i will look the spring around to see if it write anythink
Edited by sotiris, 24 June 2009 - 06:28 AM.
#45 Yoshi
Yoshi
    Just On Tickover
  • 9 posts
Posted 24 June 2009 - 01:17 PM
Thank ya much. If you could push the rubber bushing to the bottom of the shock, and measure how much of the chrome shaft is showing, as well as what the measurement is from the bolt hole from top to bottom of the shock body while it's fully extended, that would help out a lot.....
Mini Spares
