What Size Wheels And Tires?
Posted 19 May 2010 - 08:24 AM
Which tires would you suggest for 13" or 15"?
Posted 19 May 2010 - 08:59 AM
You can get a greater selection of both road and track tyres for 7" rims which is what a lot of the bike enigned boys use.
My opinion on 15" rims is - they look wrong, but thats just my opinion.
Here are the ones that I know about for 7" rims, I am sure there are more out there -
Road Tyres:
Continental (195/45)
Falken (185/60)
Yoko (175/50)
Track Tyres:
Toyo R888(185/60)
Yoko A048(175/50)
have a look on Camskills website: Camskills
Edited by cptkirk, 19 May 2010 - 09:01 AM.
Posted 19 May 2010 - 05:02 PM
Posted 20 May 2010 - 09:44 PM
Are you looking for road tyres only or track tyres?
Road Tyres:
Falken (185/60)
Yoko (175/50)
Track Tyres:
Toyo R888(185/60)
Yoko A048(175/50)
Road tyres what I am looking for. 7''? Don't you mean 13''?
I just found the tyres I am looking for, the Yokohama ad08...but they are not in stock.
Edited by De Blerende Beetle, 20 May 2010 - 09:59 PM.
Posted 20 May 2010 - 09:56 PM
No no, hes talking about the width e.g. 13 x 7s...
How about the Yoko A539s?
I've got them fitted to two of my Minis and can't fault them.
Edited by Twincam, 20 May 2010 - 09:57 PM.
Posted 20 May 2010 - 10:09 PM
I want to use the car on the road and in the dry semi slicks like the R888 or V70A are perfect...untill you come across some wet surface.
So I really like to know if anybody has usedthe semi-slicks on the road in the wet?
Posted 21 May 2010 - 07:16 AM
Road Tyres:
Falken (185/60)
Yoko (175/50)
Track Tyres:
Toyo R888(185/60)
Yoko A048(175/50)
My Bad, yes I did mean 13x7, I was thinking too far ahead about width of wheel to what tyre you can fit.
If 15" is the way then go for it.
I havent driven on track tyres in the wet so cant comment, I heard that they arent to bad until you hit stnding water then they are rubbish.
Posted 25 September 2010 - 08:58 PM
Posted 08 October 2010 - 02:58 PM
Road Tyres:
Falken (185/60)
Yoko (175/50)
Track Tyres:
Toyo R888(185/60)
Yoko A048(175/50)
what compound did you order? im thinking of getting some r888's now
http://www.camskill....1506s4429p57414
or
http://www.camskill....1506s4429p57415
Posted 11 October 2010 - 06:14 AM
Road Tyres:
Falken (185/60)
Yoko (175/50)
Track Tyres:
Toyo R888(185/60)
Yoko A048(175/50)
what compound did you order? im thinking of getting some r888's now![]()
or
I ordered medium compund and have found them to be fine in the dry, dont ask what their like in the wet as I dont intend to find out - not so much a chicken ******* more dont fancy the clean up job and promotion of rust.
One thing I would say negative about them is that the sidewall is a bit flimsy and if your going to move up to 60 profile tyres from a smaller profile you will notice the difference. My plan is to wear the rears out on mine and replace with the 225/45 R888's, this should make the rear more stable as it'll drop the rear considerably and the tyre roll will be reduced. I am happy with the performance from the front tyres at this time but will be trying different tyres in the future just to see what they are like.
Guest_Jenny2_*
Posted 29 December 2010 - 05:17 AM
Posted 16 January 2011 - 08:03 PM
does anyone have any experience with these tyres?
on another question do you have any idea about 8" wide wheels? what off-set do you buy for a zcars mini?
Posted 17 January 2011 - 09:56 AM
just looking into this again as i am needing a rear pair. i have found that toyo r888 225/45/13 's are quite a bit cheeper now, but i have concerns that they are too wide for 7 inch wide wheels.
Toyo quotes 7-7.5-8inch for this tyre
Posted 17 January 2011 - 03:43 PM
I have 8" wheels on my rear and my offset from the rim to the back of the centre hub is 92mm, what that offset is I am unsure but hopefully that'll point you in the right direction.
Where are you looking to buy tires from as if they are a bit cheaper now I might purchase some myself....
Posted 17 January 2011 - 07:28 PM
well i thought i found a link that was about £40 less than i found a while back...
http://www.camskill....d=m12b99s3739p0
seems to be £108 inc vat instead of the same tyre at 145 inc vat...
http://www.camskill....1506s4429p57418
. hmmm
