Minor Rust On A Freshly Painted Shell?
24 replies to this topic
#1 analogue_radio
analogue_radio
  • 4,897 posts
Posted 15 May 2012 - 12:50 AM
I've got a tiny bit of rust around my N/S headlight.
It's fully undersealed and waxyol'd behind & this area will be covered up my the headlight seal & bowl so it isn't visible. But I want to stop and treat it now.
How do I go about doing so?
#2 james94
james94
  • 337 posts
  • Local Club: eastbourne mini club
Posted 15 May 2012 - 07:46 AM
take it back with some sand paper then sand the rust away with more course stuff and red oxide primer it then just get that little area painted :)
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,169 posts
  • Name: Neil
Posted 15 May 2012 - 09:48 AM
Bloody hell that's gutting seeing as its just finished. You will have to take it back to bare metal then see if its just surface rust. If so treat it with Krust or another product of your choice. If its pitting slightly then you may have to spot blast it. At least this will keep any paint damage localised. If its bad pitting then maybe you will have to think about replacing that small section. Not the thing you want to hear i know but its possibly something that may have to be done.
Once that's done where you have the seam try and force some rust treatment in there. Then some zinc rich primer followed by sealing the seam like i did on Erm. Then prime and top coat.
#4 mini_in_progress
mini_in_progress
  • 641 posts
Posted 15 May 2012 - 10:04 AM
i was about to say simalar... as you wont see it id seam seal it too... but the top pic looks astho theres no paint in the seam...
Edited by mini_in_progress, 15 May 2012 - 10:06 AM.
#5 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 15 May 2012 - 06:20 PM
new or old wing?
#6 JonnyBMX
JonnyBMX
  • 865 posts
  • Local Club: Rebels
Posted 16 May 2012 - 08:00 AM
:| rust coming through that fast?? did you make sure you cut it all out/ sanded it all back to clean metal before the spray?
#7 03jkirk
03jkirk
  • 465 posts
Posted 16 May 2012 - 03:41 PM
this shouldnt happen and i m sure that if a body shop did all the prep work they should be responsible for this and should correct it at their expense because this should no happen if the shell has been prepped and painted correctly.
#8 PaulColeman
PaulColeman
  • 712 posts
Posted 16 May 2012 - 06:33 PM
I have no idea what the history is of your car but anybody restoring an old car is wasting their time unless they have the shell blasted in my humble opinion.
Paul.
#9 03jkirk
03jkirk
  • 465 posts
Posted 16 May 2012 - 06:39 PM
not wasting your time is u use good rust inhibitor as this can actually be better than blastin on seams and on metal overlaps. the best option would definatly be acid dip and e-coated after
#10 Brams96
Brams96
  • 2,308 posts
Posted 16 May 2012 - 07:24 PM
Check the pics about 1/3 down THIS PAGEto see what this guy did to solve the ring rusting issue. Extreme but well worth it IMO.
Analogue_radio - What colour have you painted your car by the way?
p.s. I can see paint gaps on the top of the ring in the first pic, are you sure the bodyshop prep'd it properly. I would contact them and ask if they will correct their mistake.
Edited by Brams96, 16 May 2012 - 07:27 PM.
#11 sonikk4
sonikk4
  • 16,169 posts
  • Name: Neil
Posted 16 May 2012 - 07:27 PM
Never thought of lead loading like that to seal all of the joints, radical approach but what a good idea.
#12 Brams96
Brams96
  • 2,308 posts
Posted 16 May 2012 - 07:29 PM
You should check out the other things he's done to his car like smoothing the bonnet & lead loading other areas. He has done a thorough & excellent job.
I was just thinking, I wonder if you could tin the edges of panels being welded together (front panel to wings etc), then spot weld them? The heat from the welding would slightly melt the lead forming a really good seal all around the weld then you could seam seal etc. It would take slightly longer to prep but would give ultimate protection.
Edited by Brams96, 16 May 2012 - 08:07 PM.
#13 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 17 May 2012 - 11:10 AM
if the painter has any pride in what he does im sure he will repair it for you, and judging by the finish of the paint, he does:)
#14 analogue_radio
analogue_radio
  • 4,897 posts
Posted 18 May 2012 - 10:16 AM
Wow didn't expect this much response.
Yeah the finish of the paint and the rest of the shell is fantastic, this is the only area that has gone a bit pear shaped.
I will email these photos through to my painted and suggest that he sorts it, as I don't fancy taking a knotted wire wheel to my fresh paint myself.
@ Brams96 - The colour is Sandy Beige.
I will let you all know any updates! Thank you!
#15 tommypope
tommypope
  • 210 posts
  • Local Club: surrey hills
Posted 18 May 2012 - 10:35 AM
looks to me like there was water under there before it was sprayed to be honest
