10S That Fit Over 8.4S
25 replies to this topic
#1 Jakeclubby
Jakeclubby
    Previously known as Jakemayfair
  • 1,669 posts
Posted 15 May 2012 - 02:36 PM
hi are theyre any 10 inch rims that are 6-7 wide thatll fit over 8.4 discs
#2 Ryang556
Ryang556
  • 2,747 posts
  • Local Club: Top Mini
Posted 15 May 2012 - 02:40 PM
I think there are but they look sh*t :D
#3 Jakeclubby
Jakeclubby
  • 1,669 posts
Posted 15 May 2012 - 02:41 PM
why?
#4 Mini-Mad-Craig
Posted 15 May 2012 - 02:42 PM
You'd need to space the wheel ridiculously to make them clear the caliper. Grinding the caliper to make them fit is a nono because they are made to tolerences and to aid heat dissipation.
7.9" brakes would give you a bit more choice, but still not a lot. MB Split Rims from (mostly) MLMotorsport clear 7.9's but you're looking at 800 for the set. You need 7.5" brakes to be able to run tens the way they were designed to run. 8.4" were designed for 12's.
Edited by Mini-Mad-Craig, 15 May 2012 - 02:59 PM.
#5 Jakeclubby
Jakeclubby
  • 1,669 posts
Posted 15 May 2012 - 02:43 PM
13s it is then :L
#6 Mini-Mad-Craig
Posted 15 May 2012 - 02:44 PM
For the price of 13's you could buy a nice Cooper S brake set up and find some tens with rubber though I bet. If you want 10's get tens, but do it properly.
#7 Jakeclubby
Jakeclubby
  • 1,669 posts
Posted 15 May 2012 - 02:46 PM
okkkkkkkk
#8 Jakeclubby
Jakeclubby
  • 1,669 posts
Posted 15 May 2012 - 02:47 PM
i wouldnt be able to fit the brakes tho
#9 minimaxie
minimaxie
  • 1,687 posts
Posted 15 May 2012 - 02:50 PM
im gonna save up for 10's for one day, and the cooper s brake conversion. much more worth while than having to settle for a limited choice like craig says
#10 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Why not?? :unsure:
#11 Jakeclubby
Jakeclubby
  • 1,669 posts
Posted 15 May 2012 - 02:55 PM
also another question my tyres on my 12x6s look quite narrow due to they are quite round can i get any squarer and wider ones for them?? maybe a smaller profile
#12 Jakeclubby
Jakeclubby
  • 1,669 posts
Why not?? :unsure:
i cant do anything :L wouldnt know where to start
#13 Mini-Mad-Craig
Posted 15 May 2012 - 02:58 PM
why do you want square tyers? :geek: :geek:
#14 Midas Mk1
Midas Mk1
  • 5,823 posts
  • Local Club: S.U.N.M.C
Posted 15 May 2012 - 03:00 PM
Narrower arches would be the easiest solution, loads of people fit wide wheels, then even wider arches, losing the whole wide 'poke that they intended to have. =]
#15 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 15 May 2012 - 03:04 PM
come to cornwall you can buy square tyres for your square wheels here
