10S That Fit Over 8.4S
#16
Posted 15 May 2012 - 03:17 PM
#17
Posted 15 May 2012 - 03:22 PM
i cant do anything :L wouldnt know where to start
i wouldnt be able to fit the brakes tho
Why not??
Well to be fair it's a fairly straight forward task that really only needs basic tools, (a single person brake bleeding kit & a breaker bar would also make the task much easier). A Haynes manual will explain how to remove and replace the calipers, discs, pads and drive flanges and all you are really doing is replacing these with slightly smaller versions.
This guide with photo's from the FAQ section explains how to remove/replace the discs and pads on a classic mini and should therefore give you some idea of what's involved. http://www.theminifo...discs-and-pads/ . At the end of the day it's going to get pretty expensive to own a classic mini, if you aren't prepared to learn how to do this sort of work yourself.
#18
Posted 15 May 2012 - 03:33 PM
#19
Posted 15 May 2012 - 03:51 PM
#20
Posted 15 May 2012 - 04:20 PM
Don't even need the pillar drill to be honest :). Fiesta calipers are the way to go, especially when you already have most of the parts on your car.Another option is the Fiesta conversion, can be done for around £100. All you need is a pair of MK1 or MK2 Fiesta calipers, 2 Metro Turbo drive flanges and a set of custom hoses. There is some very simple machining to do on the hub, but anyone with a pillar drill and a file can do it. The thread needs to be drilled out of the hub as the Fiesta bolts screw into the caliper. I did this conversion and they are great brakes! And all but a few 10's fit.
#21
Posted 15 May 2012 - 04:25 PM
also another question my tyres on my 12x6s look quite narrow due to they are quite round can i get any squarer and wider ones for them?? maybe a smaller profile
come to cornwall you can buy square tyres for your square wheels here
You mean like these?
#22
Posted 15 May 2012 - 05:09 PM
#23
Posted 15 May 2012 - 05:52 PM
OMG THANKUwhat about these, anyone tried them?
http://www.minispeed...ms-set-4-wheels
THESE ARE NICE ASWELL :L
#24
Posted 15 May 2012 - 05:53 PM
#25
Posted 15 May 2012 - 05:55 PM
#26
Posted 15 May 2012 - 06:05 PM
