Mini Engine Just Wont Be Nice Lol
Posted 17 May 2012 - 08:42 AM
It sounds like the starter motor is still in place which is stopping the engine starting but i have checked and this is not the case.
Been throughg the whole engine check everything but still no joy, been in the haynes manule front to back but that hasnt helped!!! any ideas guys would be great many thanks
Posted 17 May 2012 - 08:49 AM
Posted 17 May 2012 - 08:51 AM
Are the ht leads in the correct order, which should be 1-3-4-2 i believe, anticlockwise around the dizzy.
Yep these are in the right order lol checked it about 3 times
Posted 17 May 2012 - 08:59 AM
Posted 17 May 2012 - 09:06 AM
Have you tried pouring a small amount of fuel in the intake to rule out fuel problems?
yep tried that aswell lol
Posted 17 May 2012 - 10:00 AM
Posted 17 May 2012 - 12:45 PM
Posted 18 May 2012 - 08:41 AM
Have you put the dizzy drive back in the correct position?
Yep that went back in the correct position lol
did you rebuild the engine aswell ?
No just took it out cleaned it up and put it back in, It ran before (if a little rough) we took it out
Posted 18 May 2012 - 08:43 AM
check the engine earth strap, a lot of people get to this after checking everything else, if it's a bad connection it causes all sorts of faults.
I replaced it with a new one plus also ran a second one in just to be on the safe side, also redid and check all of the earthing points
Posted 18 May 2012 - 08:48 AM
New earth straps
New starter solenoid
New coil
New spark plugs ( correct gap)
New leads
New battery cable from the battery to the starter solnoid
All new connections
New fuse box plus fuses
All earthing points cleaned and checked
Posted 18 May 2012 - 08:51 AM
Edited by chris1988, 18 May 2012 - 08:52 AM.
Posted 19 May 2012 - 08:23 AM
Posted 19 May 2012 - 08:26 AM
Ballast or non-ballast
