Just The Two Engine Mounts?
18 replies to this topic
#1 Chance
Chance
  • 1,457 posts
Posted 23 May 2012 - 07:46 PM
Well replaced engine mounts and stabiliser bushes are all good but there is still slight movement and when I find the bite it will jolt the engine
Is there a gearbox mount?? Or another mount somewhere that will cause this??
#2 Algordo1100
Algordo1100
  • 774 posts
Posted 23 May 2012 - 07:58 PM
Two engine mounts. One top stabiliser, one bottom stabiliser. (gearbox)
Done
Al
#3 mike.
mike.
  • 6,176 posts
Posted 23 May 2012 - 07:59 PM
Theres a stabiliser on the side of the gearbox to the front of the subframe too if you've not done that.
What are your subframe mounts like?
Edited by mike., 23 May 2012 - 07:59 PM.
#4 Chance
Chance
  • 1,457 posts
Posted 23 May 2012 - 08:07 PM
Yeah done top stabiliser with the earth strap on
And ok to be honest bottom left stabiliser looks fine..can they be deceiving in looks?? I haven't changed them but look ok??
Subframe mounts...I have no idea :/
Are they bolted to the floor?? Is there just two of those? Either side??
#5 mike.
mike.
  • 6,176 posts
Posted 23 May 2012 - 08:13 PM
Subframe theres 6 mounts. I think the main ones that can give you a knock at the the ones mounted to the floor near the pedals. Check the condition of the floor around the mounts.
#6 Chance
Chance
  • 1,457 posts
Posted 23 May 2012 - 08:16 PM
Thanking you
Haynes manual will tell me where they are I assume?? I'll rip up the carpet and have a look there :) I'll find all the mounts and see whats going on :)
#7 mike.
mike.
  • 6,176 posts
Posted 23 May 2012 - 08:18 PM
Yeah, theres 2 on the front panel of the car under the bumper, 2 on the bulkhead crossmember of the car behind the little triangle pieces connected to the inner wings, and then the 2 floors ones.
#8 sledgehammer
sledgehammer
  • 3,129 posts
Posted 23 May 2012 - 08:24 PM
the ones by the rack tend to catch the oil - so the rubber seperates
they are easy enough to change - if you like oil / muck
#9 Chance
Chance
  • 1,457 posts
Fantastic
Cheers for that :)
#10 Chance
Chance
  • 1,457 posts
Posted 23 May 2012 - 08:26 PM
Yeah love the oil and muck me :P
Fairly confident it's none of the engine mounts/stabilisers so looks like I've found my next job :)
#11 tiger99
tiger99
  • 8,584 posts
Posted 24 May 2012 - 04:13 PM
Don't bother changing the subframe mounts, as the rear ones break very quickly, even when not exposed to oil. Just replace all six with a solid mount kit. It really does improve the handling.
Don't mix solid and rubber mounts, or you will regret it, because the shell will crack.
#12 Chance
Chance
  • 1,457 posts
Posted 24 May 2012 - 04:49 PM
How come they fail all the time???
Ive heard solid mounts can crack the floor anyway??
Thanks for the heads up but I think as it's a standard 998 I'll probably just replace with standard mounts
I thought the solid ones were more for performance cars...with more power and all that??
#13 Joseph-C
Joseph-C
  • 383 posts
Posted 24 May 2012 - 04:58 PM
early minis all had solid subframe mounts, that's how they were designed; they changed to rubber in the 70's to appease the new demographic so there's no need for it to be a performance car to have solid subframe mounts.
#14 Chance
Chance
  • 1,457 posts
Posted 24 May 2012 - 05:50 PM
Ohhh right thanks for the info
I assume the rubber ones work though?? Or are the solid ones an upgrade really worth it?
Assume there is price differences?
#15 Chance
Chance
  • 1,457 posts
Posted 25 May 2012 - 01:49 PM
Right had a look today and i found four...the floor ones and the front two
The only one that looked bad is the drivers side floor one as it looks like the rubber has come away from the metal..but the others seem fine
Im about to go and search for the other two :)
Ahh I assume its the two big nuts :)
If I fit solid kit at front should you fit solids at the back?? :)
Edited by Chance, 25 May 2012 - 02:57 PM.
