12G295 Head
Posted 24 May 2012 - 06:09 PM
because that seams alot to me? :/
Posted 24 May 2012 - 06:37 PM
Posted 24 May 2012 - 07:16 PM
Edited by coopdog, 24 May 2012 - 07:31 PM.
Posted 24 May 2012 - 08:34 PM
You need about 26.5cc's for a suitable compression ratio, with a standard cam.......
what does the cam have anything to do with it?
Posted 24 May 2012 - 08:40 PM
Posted 24 May 2012 - 08:47 PM
YOu can run a higher comp ratio with a higher lift cam
im going to use an mg metro cam
Posted 24 May 2012 - 09:29 PM
Posted 24 May 2012 - 09:58 PM
Posted 25 May 2012 - 08:09 AM
Posted 25 May 2012 - 09:28 AM
Posted 25 May 2012 - 09:31 AM
Posted 25 May 2012 - 10:00 AM
Posted 25 May 2012 - 10:15 AM
Posted 25 May 2012 - 10:28 AM
Engine size 998cc
Assuming flat top pistons with no dish and TDC to deck + piston rings area of about 1.5 cc
head gasket compressed volume - 2.8cc (some are 3.4)
chamber volume - 25cc
998/4 = 249.5
1.5 + 2.8 + 25 = 29.3
(249.5 + 29.3) / 29.3 = 9,51
So theoretical CR is 9.51:1
Try to work out the real piston area cc and head gasket volume (its also quoted by the producer by the way) to do more accurate maths.
(Edited wrong cc though)
Edited by jaydee, 25 May 2012 - 10:30 AM.
Posted 25 May 2012 - 10:40 AM
