12G295 Head
23 replies to this topic
#16 jaydee
jaydee
  • 8,565 posts
Posted 25 May 2012 - 10:45 AM
If you want you can even go further, like measuring all chambers in the cylinder head to either 'balance' them or calculate the avarage chamber volume.. :P
#17 thebullet
thebullet
  • 1,337 posts
Posted 25 May 2012 - 10:48 AM
If only I knew more about Minis when I was helping with my engine restoration.
#18 coopdog
coopdog
  • 4,506 posts
Posted 25 May 2012 - 11:02 AM
ah ok, so it should be ok?
i got pistons which ive heard sit a tiny bit down the bore plus they are +60 so maybe it will be ok?
#19 coopdog
coopdog
  • 4,506 posts
Posted 25 May 2012 - 01:53 PM
just got an app of itunes called mini head,
Engine cc 1050
piston dish cc 0
Ring land cc 0.70
gasket cc 2.00
piston/deck cc 0.83
Total volume cc 3.53
Chamber volume cc 25
upswept volume cc 28.53
swept volumecc 262.50
Compression ratio 10.20
is that right?
#20 jaydee
jaydee
  • 8,565 posts
Posted 25 May 2012 - 01:59 PM
+60 makes it a 1046
flat top pistons + TDC to deck + piston rings land about 1.5 cc
head gasket compressed volume - 2.8cc (some are 3.4)
chamber volume - 25cc
1046/4 = 261.5
1.5 + 2.8 + 25 = 29.3
(261.5 + 29.3) / 29.3 = 9,92
So theoretical CR is 9.92:1
I think it should be okish, once carbon biulds up it will be more like a 10:1 CR.
Sounds fine to me.
#21 coopdog
coopdog
  • 4,506 posts
Posted 25 May 2012 - 02:33 PM
thats good then :D
#22 Spitz
Spitz
  • 1,716 posts
Posted 25 May 2012 - 02:45 PM
What is this meaning?
"upswept volume cc 28.53"
#23 coopdog
coopdog
  • 4,506 posts
Posted 25 May 2012 - 03:44 PM
poop knows :L
was on the app, one of the values that was automaticly done
#24 jaydee
jaydee
  • 8,565 posts
Posted 25 May 2012 - 03:49 PM
Volume at TDC.
