Flashing Tape Or Dynamat
15 replies to this topic
#1 adamjohnson1990
adamjohnson1990
  • 64 posts
Posted 07 January 2013 - 07:33 PM
I'm really lost with all the different answers to this question loads of people say Ye use flashing tape and there is the same amount saying don't bother.
I have a mini van which I would like to sound deaden and really don't have a huge budget but a large place to cover.
What shall I do????
HELP!!!
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 07 January 2013 - 07:35 PM
if on a budget use flashing tape
if you have a bigger budget and want the better job buy dynamat
you get what you pay for
#3 adamjohnson1990
adamjohnson1990
  • 64 posts
Posted 07 January 2013 - 07:37 PM
Is there really such a big difference?
How about flashing tape with a good sound proofing foam over the top?
#4 conlad
conlad
    Previously known as ct16mini.
  • 2,054 posts
  • Local Club: Hilltop Minis
Posted 07 January 2013 - 07:38 PM
Big difference...
Just buy a cheapo version of dynamat... Silent coat is great like this http://www.ebay.co.u...=item2c64ff9dfe
#5 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 07 January 2013 - 07:39 PM
Something to note with deadening, 100% coverage is not needed, in fact 25% is sufficient. Look at silent coat, it's just as effective but cheaper.
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 07 January 2013 - 07:41 PM
Dynamat is not a dense as flashing tape, however, the main purpose of sound deadening is to stop resonance through the panels, or boom.... Flashing tape does this very effectively by adding weight to the panel, Dynamat does the same thing but is more of an acoustic solution. IMO...
The difference comes when you can do a whole car with flashing tape for the same price as a few sheets of dynamat
#7 adamjohnson1990
adamjohnson1990
  • 64 posts
Posted 07 January 2013 - 07:48 PM
Ok so how much should I use and where should I cover with how much
Is it worth doing the whole of the floor with flashing tape and then wheel arches and patches on the side and roof with silent coat?
What about the foam stuff like this stuff http://www.deadening...tor-8-pack.html do I go over everything with this or acoustic carpet?
#8 Hegnirst
Hegnirst
  • 3,496 posts
Posted 07 January 2013 - 08:53 PM
my car is fully flashing taped and ill tell you know, its bloody awesome!
my car is silent on the inside even with a weber under the bonnet :)
#9 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 07 January 2013 - 09:02 PM
As said already. flashing tape is basically a 'mass loader' to add density to a panel, where as Dynamat and silentcoat etc do more than add mass they turn vibration in to very low level heat.
Flashing tape will do the job 'to a point' where as deadening sheet are designed for the job,
#10 adamjohnson1990
adamjohnson1990
  • 64 posts
Posted 07 January 2013 - 09:53 PM
So on a budget do you think a mix is a good idea?
So do I just put a couple of sheets in the centre or cover the whole lot?
#11 freshairmini
freshairmini
  • 1,718 posts
Posted 09 January 2013 - 03:52 PM
What I would do is get some decent sound deadening (silent coat, dynamat etc...) in a small amount to start on the important areas. You can get a small pack of the 2mm sheets for like £20 ish ( http://www.caraudiod...t-door-kit.html ) it'll get you started. Once more fund become available do more.
#12 screech
screech
  • 3,136 posts
  • Local Club: Bognor rock ya mini & WSMOC
Posted 13 January 2013 - 11:12 PM
From personal experience, I found flashing tape to be quite literally, useless.
I've now gone with silent coat. Does exactly what it says it should.
IMO, do it right first time round.
#13 Wigeon Incognito
Wigeon Incognito
  • 294 posts
  • Local Club: Essex Mini Club
Posted 31 January 2013 - 08:24 PM
Just to ride on the back of the original question here, is Silent Coat water resistant? I know Silent Coat Isolator and Absorber are but it's the aluminium backed damping material I'm interested in.
#14 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 31 January 2013 - 08:29 PM
Yes it is.
#15 Wigeon Incognito
Wigeon Incognito
  • 294 posts
Posted 31 January 2013 - 08:35 PM
That's a nice quick answer, thanks for that!
