Which Dizzy To Buy?
18 replies to this topic
#1 simonhershaw
simonhershaw
  • 65 posts
  • Local Club: Sheffield Mini Owners Club
Posted 25 May 2013 - 03:40 PM
Ok do going to order a new dizzy. I have a 1990 rover mini city 1000 (998cc)
The dizzy I'm looking at on eBay is a 45d points distributor. Just making sure this will fit my mini?
(Sorry left my Haynes in Rotherham and I've gone to work In Lincoln so can't look it up)
Thanks all :)
#2 lrostoke
lrostoke
  • 6,923 posts
Posted 25 May 2013 - 03:45 PM
Personally I'd go for this one..
http://www.ebay.co.u...=item1c2da5f90f
#3 simonhershaw
simonhershaw
  • 65 posts
Posted 25 May 2013 - 04:12 PM
That's twice the price of the one I'm looking at :/ and I'm skint :(
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 25 May 2013 - 08:28 PM
The A+ engines use a different clamp arrangement and drive dog than the earlier 45d yours should have been a 59d rather the clamp round the base it uses a fork type retaining clamp on the body to block
#5 simonhershaw
simonhershaw
  • 65 posts
Posted 26 May 2013 - 08:40 PM
I just checked on eBay and it says the clamp holding this on should be a v shape for the 59d but my current clamp is a fork shape? Does this mean I need a 45d ?
#6 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 26 May 2013 - 08:59 PM
This is the clamp for the 59D series Lucas Distributors 85-on  http://www.minispare...ic/613857A.aspx
#7 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 26 May 2013 - 09:04 PM
  You don't just need 'a dizzy', you need the right dizzy.  The components inside the dizzy set its advance curve which is effectively the ignition map for the car.  This needs to be well matched to the cam and the car's intended use.  There is a 5 number code on the side of your current dizzy, this describes the build of it.  You should really replace it with the same model.  What exactly is wrong with the one you currently have?  Most things can be fixed quite easily.
#8 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 26 May 2013 - 09:09 PM
  I think the change to the 59D was around 88 / 89.  My '90 had a 59D.  Some parts catalogues show 59D being fitted from 1980 but I don't believe that is the case.  My '84 had a 45D.
Edited by Dan, 26 May 2013 - 09:53 PM.
#9 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 26 May 2013 - 09:55 PM
  Strange.  I'm pretty sure the '89 Thirty I used to maintain had a 59D.  I wonder if there was a specific change point or if, since they were essentially both broadly the same, it depended on the typically vague Lucas supply chain?
Edited by Dan, 26 May 2013 - 10:02 PM.
#10 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 26 May 2013 - 10:57 PM
Most likely fitted what they had and when that ran out phone up ducellier ?
#11 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 27 May 2013 - 04:05 AM
As an aside...powerspark are worth the price and the tech help is very good. I would personally spend a bit more with PS.
#12 Spud_133
Spud_133
    mmm potato and cheese....
  • 1,689 posts
  • Local Club: C&T Classics
Posted 27 May 2013 - 06:48 AM
My old '82 HL also had a 59D, I guess it's just BLs that'll do mentality.
#13 lrostoke
lrostoke
  • 6,923 posts
Posted 27 May 2013 - 07:32 AM
must be what comes out the parts bin
3 I've seen 84 , 88 and 89 all 59D
#14 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 27 May 2013 - 11:24 AM
  Well actually now I think about it, out of mine the one that I know wasn't original was the '84 with the 45D.  It was an import with a much older, A series engine.  I know my Checkmate was originally fitted with a 59D because it had the proper F16 engine number which was unique to the Racing / Flame / Checkmate.
#15 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 27 May 2013 - 11:32 AM
my 1989  998 had a 59D, i changed it to a 65D (electronic) and its been great.
