Cones Or Springs
Posted 25 May 2013 - 08:09 PM
The car is an otherwise fairly standard mpi sportspack with polybushed suspension. I'd like a slightly softer ride but this might happen anyway if I fit new standard cones. don't want to fit replacement dampers if I can help it.
What do you folk think?
Posted 25 May 2013 - 08:16 PM
red dot rubber cones are very good i hear.
Posted 25 May 2013 - 08:30 PM
Red dot cones are good (I've got them fitted), but they are firmer than standard and seeing as the OP wants a softer ride i'd go for either the standard cone or for Moulton's comfort kit. Stay away from coils....rubber is best.
Posted 25 May 2013 - 08:31 PM
Posted 25 May 2013 - 08:52 PM
To add a spanner to the works, I have the Minitastic coils, fast road, and they are damn good. Much more compliant ride than my 2000 mile old cones, I can take speed bumps at the same speed as normal traffic and dont have to swerve for pot holes. No deterioration in handling either.
Posted 25 May 2013 - 09:11 PM
I have to agree I have coil springs and Gaz dampers and the rides really very good for a mini, horse for courses but cant do a back to back but works well on my setup
Posted 25 May 2013 - 09:29 PM
Miniman, do you have standard dampers?
Posted 25 May 2013 - 09:44 PM
I've got Mini Delta Fast Road Springs and Pro Tech Dampers.
It's definitely a more compliant ride whilst not loosing the classic Mini feel. The handling is amazing as well. Mine has been corner weighted and the suspension was setup by Peter Vickers so that kinda helps!
Although saying that my bro's Cooper S has good olde rubber cones on it and his is still fantasitic fun! It's just a bit more of a harsher ride compared to mine.
Posted 26 May 2013 - 02:25 PM
Im running Gaz adjustables set in comfort mode most of the time, 2 clicks up front and 4 at the back. If I feel like thrashing it I go to 8 clicks up front and 12 on the back :)
Posted 26 May 2013 - 02:41 PM
Posted 26 May 2013 - 03:21 PM
Yeah you have to have hi-los with the springs, and I cant compare the Gaz shocks with standard ones as Ive only ever had Gaz ones :)
Posted 26 May 2013 - 07:00 PM
Posted 27 May 2013 - 04:18 PM
Till you put a full load in the car and find that the coils are bottomed, so when you hit a bump something breaks.
It has been said many, many times, here and elsewhere, that a car with short travel suspension like the Mini must have either a self-levelling system (impractical, unless you can graft in some Citroen bits) or rapidly rising rate springing, such as can only be achieved with rubber. Nothing else can accomodate load changes properly, and note that HiLos DO NOT give the kind of adjustment necessary.
So, if you ever want to give 3 of your friends a lift in the car, coils are complegtely unsatisfactory. On a competition car that runs at constant weight (except for fuel) they may well be good.
Posted 27 May 2013 - 04:27 PM
You say that Tiger, but on the Minitastic's I have had 3 passengers and luggage with zero problems, and we went over some pretty rough roads! I felt no evidence of coil binding when driving, and Ive just been out to inspect the coils to confirm, there are no signs of the windings of any coil touching (paint scuffs/scratches). The top arm would definitely hit the bump stop before the coils became coil bound anyway.
Posted 27 May 2013 - 04:29 PM
And Ive fitted hydrolastic bump stops to the radius arms to prevent this at the rear also.
