1987 City E
189 replies to this topic
#16 BronkoMini
BronkoMini
  • 1,484 posts
  • Local Club: Mini Fixers
Posted 18 March 2014 - 06:24 PM
I tried putting a screw driver in but it felt like it was going to snap, I shall try the other ways mentioned tomorrow.
Thanks for the replies
#17 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 18 March 2014 - 09:15 PM
If the washer is that tight, you may have to resort to a small chisel in the split once it breaks the seal it will come out fine. As, as been said it could be that the wheel bearings have seized on the cv shaft plenty of penetrating fluid and gentle persuasion with a hammer on the hub flange protected with a piece of wood should get it moving, a hub puller, if you have one may also help.
#18 BronkoMini
BronkoMini
  • 1,484 posts
Posted 19 March 2014 - 02:40 PM
Edited by BronkoMini, 19 March 2014 - 04:09 PM.
#19 BronkoMini
BronkoMini
  • 1,484 posts
Posted 19 March 2014 - 03:49 PM
Skip above found out answer, new problem put disk on and caliper started to torque up hub bold when it started spinning, then it didn't spin and it is locked on, so I have taken of calliper and the disk won't come of now any ideas?
5CCBFB5B-2FA5-48FB-BFCC-75627E874213_zps
#20 BronkoMini
BronkoMini
  • 1,484 posts
Posted 19 March 2014 - 04:11 PM
Just put the hub bolt back on and it spins but only one you get over 200nm so I tried tacking the disk of again big it still won't move and help would be much appreciated
#21 BronkoMini
BronkoMini
  • 1,484 posts
Posted 19 March 2014 - 06:03 PM
Sorted with the use of a crow bar, the problem was the dirt between the hub outer bit and the inside of the disc
#22 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 19 March 2014 - 07:45 PM
Good news, I am pleased for you.
#23 BronkoMini
BronkoMini
  • 1,484 posts
Posted 19 March 2014 - 09:15 PM
Thanks now I've got to do the other side tomorrow, but I now know what to do if it doesn't work like today.
#24 BronkoMini
BronkoMini
  • 1,484 posts
Posted 19 March 2014 - 09:16 PM
Rookie mistakes
#25 BronkoMini
BronkoMini
  • 1,484 posts
Posted 20 March 2014 - 11:04 AM
Now I can't get the hub nut of the other side
#26 BronkoMini
BronkoMini
  • 1,484 posts
Posted 20 March 2014 - 03:00 PM
So I tried using the washing line pole as extra leverage and managed to bend it, oops, the problem is I can't go out and get a scaffold pole or something as mate is un drivable, so now I have started on fitting my stage one kit, managed to unbolt the manifold, but it's stuck to the pipe, nothing is ever straight forward .
#27 BronkoMini
BronkoMini
  • 1,484 posts
Posted 20 March 2014 - 06:24 PM
Another problem do these gaskets go on here and also the bolts that hold the inlet manifold on to the head, are attached to the old manifold and the new one does not have any? What do I do?
AB11EE7E-9FA2-4CAB-ABD5-660F558B438A_zps
#28 minimk1
minimk1
  • 917 posts
  • Local Club: a's of herts
Posted 20 March 2014 - 06:40 PM
they don't have gaskets on there as this area goes onto the head, the head has an exhaust and inlet gasket which is one gasket also it should just bolt on with nuts and shouldn't need any bolts
#29 minimk1
minimk1
  • 917 posts
Posted 20 March 2014 - 06:41 PM
this is the gasket
http://www.ebay.co.u...=item2c7e82ecec
#30 BronkoMini
BronkoMini
  • 1,484 posts
Posted 20 March 2014 - 08:27 PM
this is the gasket
I have that gasket, and three of the small ones, I take it one of then goes from the inlet to carb and the other behind the plate think big where does the third one go as I have taken of the other two but can't find a third one? The inlet bolts to the head but where the carb goes on the inlet there is no bolts as the y were on the old manifold, so I'm not sure what to do there, thanks for the help
