If I had more room I'd have run two New Era relays, one for the drivers side and one for near side lights.. might upgrade to another one down the track.
Just incase the bright LEDs get annoying, I bought some electronics gubbins today to make up a dimmer circuit for the shift/rpm lights. You shouldn't just dim LEDs with a higher resistor or potentiometer, they don't dim too well that way - you should ideally make a PWM (Pulse width modulated) driver, and the duty cycle of the pulses changes the brightness of the LED. put a potentiometer onto a 555 timer and you have an adjustable PWM driver. I'm using the circuit from here:
http://pcbheaven.com...LED_PWM_Dimmer/
I am computer engineer.. We had these stuff with led traffic lights as laboratory class. I still rembember connecting wrong the poles and the crapy thing didn't work. Awesome Job mate
