1971 Mini K (Australian)
79 replies to this topic
#46 sixtyeight
sixtyeight
  • 630 posts
  • Local Club: forums.minidriver.com.au
Posted 27 October 2016 - 07:35 AM
made a nice little aluminium voltage regulator today..
out of some:
scrap aluminium
3D printed end caps
LM350T
resistors
a capacitor
some wire
some heat shrink
some screws
the spade connectors from an original vreg.
total cost - ~$3.00
Edited by sixtyeight, 27 October 2016 - 07:37 AM.
#47 clovus
clovus
  • 231 posts
Posted 28 October 2016 - 11:34 AM
Great work Tim!
#48 sixtyeight
sixtyeight
  • 630 posts
Posted 30 October 2016 - 12:22 PM
finally got everything prepared for wiring. I hadn't painted the upper and lower dash rails so couldn't perma-mount the interior - wheel, heater, megajolt, switch panel etc etc, so did that today - turned out ok with limited time! excuse the crappy photo
then mounted up the fuse boxes on the inner wing - I wanted to put them up on the firewall but no room.
Edited by sixtyeight, 30 October 2016 - 12:23 PM.
#49 sixtyeight
sixtyeight
  • 630 posts
Posted 31 October 2016 - 07:45 AM
so made a start on the wiring.. 2 wires connected! still a nice little milestone.
all the right stuff:
alternator and temp sender
#50 timmy850
timmy850
  • 3,560 posts
  • Local Club: MITG
Posted 03 November 2016 - 09:19 PM
bleedin' 'eck..
translucent reservoirs would make this easier than the tin can ones!
You can get translucent master cylinder extension pieces from the usual suspects so you can keep an eye on the fluid level..
http://www.minispare...cs/BHA4661.aspx
#51 sixtyeight
sixtyeight
  • 630 posts
Posted 04 November 2016 - 03:40 AM
Ah thanks for that! Will keep that in mind for next time
#52 sixtyeight
sixtyeight
  • 630 posts
Posted 19 November 2016 - 12:29 PM
no big update.. still not running.
have made up a switch panel out of 3mm aluminium with a big engine start button, because I like engine start buttons!
90% of my way through running the wires. all the front is run, just need to run the rear stuff, terminate all the ends, and then cover the loom in self amalgamating silicon tape.
just a mess of wires at the moment!
#53 xydte
xydte
  • 142 posts
Posted 20 November 2016 - 03:18 AM
awesome work. Especially underneath the car!!
#54 sixtyeight
sixtyeight
  • 630 posts
Posted 23 November 2016 - 08:20 PM
Cheers xydte :)
Have made up a mount for tacho and shift lights (from megajolt), out of some scrap aly and 3d printer
#55 sixtyeight
sixtyeight
  • 630 posts
Posted 24 November 2016 - 07:00 AM
finished off the enclosure for the leds today. put a panel mount rj45 connector in to attach it to the megajolt. quite happy with how it has turned out! Just waiting for the LEDs to turn up and can then finish off the wiring.
#56 sixtyeight
sixtyeight
  • 630 posts
Posted 27 November 2016 - 01:57 PM
had a busy evening with the strippers and crimpers. got the fuse boxes and relays wired up finally. was dreading doing this! Also tidied up the wiring a little, getting ready to wrap it in tape.
this is a 'New Era' headlight relay, has two relays in one for main and dip beam.
#57 timmy850
timmy850
  • 3,560 posts
  • Local Club: MITG
Posted 28 November 2016 - 09:50 AM
The wiring is looking great. Definitely an upgrade of the two fuses originally fitted! I've got a couple of the New Era relays to go in my car too
#58 sixtyeight
sixtyeight
  • 630 posts
Posted 29 November 2016 - 06:46 AM
If I had more room I'd have run two New Era relays, one for the drivers side and one for near side lights.. might upgrade to another one down the track.
Just incase the bright LEDs get annoying, I bought some electronics gubbins today to make up a dimmer circuit for the shift/rpm lights. You shouldn't just dim LEDs with a higher resistor or  potentiometer, they don't dim too well that way - you should ideally make a PWM (Pulse width modulated) driver, and the duty cycle of the pulses changes the brightness of the LED. put a potentiometer onto a 555 timer and you have an adjustable PWM driver. I'm using the circuit from here:
http://pcbheaven.com...LED_PWM_Dimmer/
Edited by sixtyeight, 29 November 2016 - 06:47 AM.
#59 sixtyeight
sixtyeight
  • 630 posts
Posted 29 November 2016 - 11:08 AM
continuing the nerdy stuff..
I made the PWM dimmer for the shift lights tonight. it just fits in the housing! Nice black anodised aluminium adjustment knob.
#60 sixtyeight
sixtyeight
  • 630 posts
Posted 05 December 2016 - 08:54 PM
rpm/shift lights and tacho housing finished and mounted
