Project Van, 1969.
173 replies to this topic
#46 leeuk
leeuk
  • 681 posts
Posted 20 June 2014 - 11:40 AM
Original Dunlop's are being refurbished for the van, I do like to see Dunlop's on the vans ;-)
Here is one that was prepared earlier...
Attached File  van wheels 4.JPG   46.55K   8 downloads
Click on the images for larger picture`s ;-)
Edited by leeuk, 04 October 2014 - 11:13 AM.
#47 Archived2
Archived2
  • Archived
  • 1,093 posts
Posted 20 June 2014 - 02:53 PM
You left enough room for paint in those gaps?  ;D
Edited by minihobbymini, 20 June 2014 - 02:53 PM.
#48 leeuk
leeuk
  • 681 posts
Posted 20 June 2014 - 03:54 PM
Im hoping so mate, They should be good lol ;-)
I managed to get some primer onto it today after I had finished filling the dinks on the bonnet and wings.
I'm quite happy with how its turned out..
Attached File  van front panels 25.jpg   29.66K   1 downloads
First coat of primer on ;-)
Attached File  van front panels 26.JPG   38.83K   4 downloads
I couldn't resist but quickly drop the bumper on,
Attached File  van front panels 28.JPG   49.49K   6 downloads
I think I've done pretty good for my first attempt :D
#49 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,157 posts
  • Name: Sean
Posted 28 June 2014 - 08:11 PM
Well, in orde to help Lee get the van to the IMM i have it for a little while!!!  Plan is to get the back end welding done. the brakes and clutch working and the engine running!!
Once thats done he can have it back!!
Had a session on it today..
10458010_10153110099224119_5921472629785
10422172_10153110097359119_7585501447537
10520692_10153110096059119_2231547748815
10407513_10153110095309119_6690822169113
10514661_10153110094709119_1469008632254
The back end pretty ropey, you can wobble it around like a jelly!!
Time for some welding....
10427311_10153110094179119_2987540781657
10357116_10153110093629119_4939273274314
10441027_10153110093059119_4848421868477
I've also added some reinforcing as well
1555347_10153110092519119_89997656465202
10349215_10153110138149119_2396702137891
The other side was better
10478945_10153110091959119_5749948306597
10350407_10153110138269119_4134669314781
10418153_10153110137854119_4984096433517
The work has been inspected...
10450735_10153110138629119_1632672692422
#50 leeuk
leeuk
  • 681 posts
Posted 28 June 2014 - 08:54 PM
No more jelly bum ;-)
Nice work mate It was in desperate need for that, Time is ticking down for IMM but I believe we will have it ready, No problem,
The van is going straight to Wayne "Street Tweeks" over at Car Perfection near to Wolverhampton straight from Shifty where it will undergo its final transformation into a minter..
"Watch this space !!" lol
#51 Shifty
Shifty
  • 13,157 posts
  • Name: Sean
Posted 28 June 2014 - 09:01 PM
Yup, the back end doesn't wobble now!!
When it was on the trailer I could see it shaking in the rear view mirror!!!
#52 leeuk
leeuk
  • 681 posts
Posted 28 June 2014 - 09:05 PM
I bet that was a sight to see for those sitting in the car behind the trailer.
Its now a solid van at each corner thou mate after todays welding,
I cant wait to get my hands back on it as I know the end is near lol ;-)
#53 Shifty
Shifty
  • 13,157 posts
  • Name: Sean
Posted 28 June 2014 - 09:13 PM
I'll get the back end finished tomorrow, hopefully do the A-panel as well.  That leaves the doors and the brakes etc to do.
With a bit of luck it will be back to you next saturday!!
#54 leeuk
leeuk
  • 681 posts
Posted 28 June 2014 - 09:23 PM
That would be ideal that would mate, It would leave me with 10 -11 days to finish the prep and then a week or so for paint and re fit so touch wood all goes to plan and we finish in time ;-)
I've also a 50s hot rod to help prep over the next couple of weeks for Car Perfection but I believe I will have enough time to get the van ready for paint, I may have to put in a few late nights towards the end but the thought of it all finished will get me there  ;-)
Attached File  50s hotrod 2.JPG   52.04K   9 downloads
Attached File  50s hotrod 1.JPG   57.28K   3 downloads
Edited by leeuk, 04 October 2014 - 11:14 AM.
#55 Shifty
Shifty
  • 13,157 posts
  • Name: Sean
Posted 29 June 2014 - 07:09 PM
Had another session on it today, not may pictures but quite a lot of progress!!
Fitted the rear valance and tided up the load bed floor, also fitted the strengthening panel that goes behind it.  If you say it quickly it sounds easy!!
The pattern valance didn't have a lot of shape and the rear floor of the van was out of shape!! I had to do a lot of reshaping on them to make it close, even then when you clamped it it pulled out of shape very easily.
What I needed to do was weld the 2 together and then shape them, impossible if you fitted the panel behind, which you had to do before you fitted the dammed valance!!
My solution was to cut the strengthening panel in 1/2!! This meant it could be fitted after the valance!!
10488369_10153112646794119_2300787129050
10500246_10153112647259119_2289780576280
Sucess!!!
Next was the welding on the rear door frame.
10505379_10153112649254119_6892895075707
10419402_10153112648269119_6141787716594
10492303_10153112648849119_1729823784001
10358873_10153112647609119_2992358209982
Still got a bit more tidying up to do on this but its strong and solid now.
I got bored of doing the backend so I had a quick look at the A-panel and door skin fit
10509748_10153112646394119_6172149966087
Seems an ok fit, needs some work but not a lot, the pattern door skin looks ok as well.
I also removed the locking wheel nuts as well!!
#56 minbin 69
minbin 69
  • 465 posts
Posted 29 June 2014 - 07:24 PM
theres me thinking i was the only one that did it that way :D hope you remembered to run something behind there to pull the wiring though??? ;D
great work as always :thumbsup:
Edited by minbin 69, 29 June 2014 - 07:25 PM.
#57 leeuk
leeuk
  • 681 posts
Posted 29 June 2014 - 07:57 PM
Loving todays work mate, Im more than glad to see its back end get sorted out its been screaming for it lol.
Yes defiantly great work as always, And some good progress made today too ;-)
#58 Shifty
Shifty
  • 13,157 posts
  • Name: Sean
Posted 30 June 2014 - 08:05 PM
Had another crack at this today, not got a lot of time and there's a lot to do!!
Still got a bit more finishing off to do on the back end but I decided to have a crack at the door instead!!
At a glance it didn't look too bad but it had been reskinned and had some dodgy repairs on the bottom.  So I dragged out my trusty door skin removal tool,,
10426903_10153114786124119_2826803073223
Pulled the skin off the door
10501625_10153114786844119_3469066808564
10487421_10153114787874119_7173432855743
Let in a new bottom..
10456136_10153114784774119_7729701515747
10501643_10153114785494119_3175939552048
The put the skin on, as this is a budget build we used pattern skins, not too bad a fit, needed a bit of tweaking..
10446476_10153114784409119_7498820726323
10462709_10153114784144119_7675838230749
10336767_10153114783724119_8682572120812
Finally tried it in the hole to make sure it still fitted..
10408559_10153114783004119_3038807749142
Not too bad, the A-panel needs to go forward at the bottom a bit, but a good start.
I'll get the back end finished next and then start on the other door.
With a bit of luck I'll get the welding and body finished in the week and then on Saturday do the mechanicals and brakes.  Still a lot to do, but getting there!!
#59 Shifty
Shifty
  • 13,157 posts
  • Name: Sean
Posted 05 July 2014 - 07:41 PM
Still at it!!
The back end welding is done and the brakes have now been overhauled, we had a delivery as well..
10514544_10153123571004119_2007358324460
Onto skinning the other door, we had one 'good' door and one 'bad door'
This is the 'good' one..
10533449_10153121575389119_3575542043547
10350514_10153121575739119_6701021951493
Yup, the good one was worse than the bad one..
10462712_10153121575869119_3701151544505
A hasty rethink meant that the bad door was now the base to be used..
10441973_10153121576454119_6006515688152
Few repairs
10436666_10153121576684119_2862247896912
10500525_10153121576809119_3358254683999
This door had a new bottom as well.
#60 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 05 July 2014 - 08:40 PM
Nice work chaps.
Best of luck getting this ready for IMM!
Ben
