Important and exciting update time!
I've not had any time over the past couple of weeks to get the doors fully finished off, and I also realised I had missed the rear seat reinforcing strip so I also now have that to fit as well.
However, I've made one very big decision now on the engine so may pause slightly on the body work, reasons are about to become clear!
Much earlier on in my thread I posted that I had bought this, as the conversion was of interest to me....
Well over the past week I have been talking to SC and today I have agreed a deal and put down a deposit so this weekend I'm going to start stripping the engine down so I can get it sent off.
I'm supplying my block and crank and they're going to supply the a K1100 16v head, throttle bodies and injectors (refurbished and machined to fit), their complete conversion kit, pistons and con-rods and are going to wedge and blade the crank and polish the journals. They will also do all the machine work on the block including centre main strap and boring to 1293 (well, that is assuming it is stock 1275, I don't know this as the engine is still fully built a the moment!), they're also going to machine the cutouts for the valves in the pistons and fit them to the rods. I'll then get the whole lot back and build the engine myself.
Oh and they're going to fabricate an oil filler into the cam cover for me as well, I've seen these on peoples build threads and they look like nice and neat solution to getting access to get oil in to the engine (the bike's oil filler is not on the cam cover so a different solution is required when fitted to the A series engine).
I'm also going to order an MED lightened flywheel kit, and guessworks gearbox recon kit and X-Pin diff, if I'm lucky I can get the gear box re-built by the time the engine gets back to me and I can crack on then with the build.
Reason for deciding to pause the body work is that having done this I'm going to have to make some adjustments to the bonnet and I don't know how extensive until the engine is built and in place so no point it getting it painted until that's all done, I may also need to make some other adjustments here and there so want to do a dry run on the install before getting it in to a paint shop. I'm hoping to get away with no bonnet bulge as I want the car to look unassuming from the outside but I'm prepared to do so if required but not going to get a bulbous 16v bonnet, they don't float my boat and shouldn't be necessary.
Unfortunately this does mean that the replacement wiring loom I had made up is now redundant, it turns out that the SPi is the worst starting point from that point of view and they advised either to switch to an MPI or late carb loom, anyway, the loom I bought I will no doubt be able to sell on as it was custom made as it is N.L.A. and the carb loom I need will be cheaper and result in a tidier engine bay, I can also install the ECU under the dash in the car which appeals to me too.
Interestingly having done the number crunching (checked and double checked) in the grand scheme of things this isn't nearly as much more expensive as I anticipated than going down the route I was heading in of; stage 3 head, racier cam and programmable ECU (in fact if I had gone for the full SC 5 port throttle body kit the difference in cost would be pretty marginal and I was leaning towards this), certainly I think the benefit is justified by the cost and will make my project that bit more interesting and unique. There's much of the work I would have done anyway regardless of which route I took with the head and there's things I don't need to purchase as they're included here and I will also get a bit back by selling on the old head etc.
Exciting times; I think I need to change the title of my thread!
Edited by alchall, 03 November 2017 - 04:57 PM.
