South African 1275Gt
193 replies to this topic
#76 Jared Mk3
Jared Mk3
  • 1,974 posts
  • Local Club: MOCKZN
Posted 19 March 2016 - 02:55 PM
The front subby is now bare. What a mission! The driver's side rubber cone had so much dirt and rubbish inside it that I couldn't get the compressor tool screwed in. Eventually got it out.
#77 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 20 March 2016 - 01:41 PM
Any plans to get Hi-los and 4 pot calipers for this car?
#78 Jared Mk3
Jared Mk3
  • 1,974 posts
Posted 20 March 2016 - 04:42 PM
Hi-Los, yes. 4 pots, no. The calipers will be redone like I did for the Mk3. New discs etc.
#79 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 20 March 2016 - 05:02 PM
A pic of a low riding GT must be taken once she is rebuilt :D
#80 Jared Mk3
Jared Mk3
  • 1,974 posts
Posted 20 March 2016 - 05:47 PM
Definitely!
#81 Jared Mk3
Jared Mk3
  • 1,974 posts
Posted 20 March 2016 - 05:49 PM
The rear frame is almost completely free of grease and grime. There is so much sand - in all the cavities!
#82 Itsaminithing
Itsaminithing
  • 856 posts
  • Local Club: Not One Worth Mentioning
Posted 20 March 2016 - 06:12 PM
Do you keep popping down to the beach at Margate? I was born just down the coast from there.
Oh, hang on wrong Margate.
You going to fit stainless brake pistons or just normal ones?
#83 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 20 March 2016 - 06:13 PM
Also in great shape Jay. Keep cracking on. Absolutely love following your build.
#84 Jared Mk3
Jared Mk3
  • 1,974 posts
Posted 20 March 2016 - 06:17 PM
This is more 'middle of nowhere' sand than beach sand - even stones are coming out.
Yes, will be fitting stainless pistons.
#85 Jared Mk3
Jared Mk3
  • 1,974 posts
Posted 20 March 2016 - 06:19 PM
Thanks for the kind words  =]
#86 Jared Mk3
Jared Mk3
  • 1,974 posts
Posted 21 March 2016 - 03:53 PM
At last! Two grease and grime free subframes :
#87 Jared Mk3
Jared Mk3
  • 1,974 posts
Posted 22 March 2016 - 02:40 PM
I realise the updates seem pointless, but I do it to keep a record of exactly when things were done, even if they're small jobs.
Finally managed to get the hubs dismantled completely today. Knocked the bearing races out; got the balljoints off and removed the steering arms :
Made a start on the lower suspension arms as well. Filed away the rough edges from the casting.
Also, I had a look at the upper suspension arms and might need to replace the LHS one due to excessive wear from the knuckle going through the nylon cup.
#88 Jared Mk3
Jared Mk3
  • 1,974 posts
Posted 23 March 2016 - 05:30 PM
The hubs and lower arms are now clean :
Time to do a little work by hand and then some paint to go on.
#89 Itsaminithing
Itsaminithing
  • 856 posts
Posted 23 March 2016 - 06:42 PM
You call that clean? -Must be the thin air at that altitude affecting your brain.
Now do it properly before i get the whip out :trooper:
Warm temperatures!.... you lucky so & so. In the UK if you left ANY trace of rust it would be as bad as before (or worse) after a year.
#90 Jared Mk3
Jared Mk3
  • 1,974 posts
Posted 23 March 2016 - 06:54 PM
Clean is considered grease free  :lol: Nah, I still have to do some work by hand before I lay any paint on there.
If I remember to do it, I'll take the shock mounts off tomorrow and show you how lucky I really am.
