I've discovered that my rear radius arm (nearside) has not been swinging on the bearings which have seized by a failure of the internal grease transfer mechanism. This resulted in the radius arm swinging the shaft in the sub-frame. This in turn has worn the shaft and the holes in the sub-frame. The outer hole is really no problem as the small bracket is detachable and replaced easily. The inner hole is now quite elongated is this a sub-frame out job or can I get away with some sort of repair patch? What's the consensus?
