Or if somebody made a mod that helps
like : FSE power boost valve
or : new throttle body
or : an new manifold like LCB
Or something else that will help
Posted 03 June 2017 - 01:53 PM
Posted 04 June 2017 - 11:10 AM
Posted 05 June 2017 - 10:09 AM
Hi everybody,...
Can it be related with the fault described on page 31/73 of https://www.uscars.b..._Bulletins.pdf, that is. cam reluctors defaults...
On the other hand,...Scott Mpi suggests "Give the tappets a bigger Gap, say 25 thou, ( essentially changing the valve timing a bit ) " ... do you refer valve rocker clearance ? By default, as you can check in attached file, the must be between 27 and 33 mm
cheers,
Jaime
Posted 05 June 2017 - 11:45 AM
Posted 05 June 2017 - 09:08 PM
Hi Scott MPI...
Thanks for your explanation... it´s very interesting....
Furthermore, I've read mpi ecu defines at least two ranges in its maps: one under 2000-2500 rpm (city use) and one over 2000-2500 (road use) .... different ranges -> different valve timing
In your opinion.... could be a kent/swifttune camshatfs the solution to avoid kangaroo problem in a standard mpi ?
Jaime
Edited by bmv133, 05 June 2017 - 09:09 PM.
Posted 06 June 2017 - 08:45 AM
Thanks for all your help,
so the first to start :
Valve Rocker clearance : but how many mm ? 20/25:27/33 ????
Posted 06 June 2017 - 08:46 AM
Second you talk about the octane :
In France we have 95 and 98 ,
I always use 98
But witch is better for our problem and for the Mini in general ?
Posted 06 June 2017 - 11:57 AM
Posted 06 June 2017 - 12:34 PM
Posted 07 June 2017 - 09:20 AM
OK thanks
Posted 07 June 2017 - 09:27 AM
But forum the genuine Rocker
Do I really have to set the valve clearance to 0.50mm ???
Sure ?
They will make the car noisier (clik/click/click....)
Posted 07 June 2017 - 10:47 AM
Posted 07 June 2017 - 12:49 PM
Never checked since : 10 years...... or more.....
Posted 07 June 2017 - 02:22 PM
Posted 07 June 2017 - 02:25 PM
