1275 S Morris Cooper 1964 Conversion To Rhd
suspension
4 replies to this topic
#1 prea356m
prea356m
    Starting My Mini Up
  • 2 posts
Posted 25 June 2017 - 08:18 AM
Hi
My car is an original right hand drive version that was converted to left hand drive from the previous owner  I would like to bring it back to the original rhd conditions .  If anyone can help me by pointing me all the parts needed for conversion ??
#2 Homersimpson
Homersimpson
  • 803 posts
Posted 25 June 2017 - 06:42 PM
From Memory:
  • Steering Rack
  • RHD Headlights
  • Brake and clutch hydraulic pipes from master cylinder to first point.
  • Possibly throttle cable depending upon length.
  • Possibly front section or wiring loom depending upon length of connections for column stalk (I would be tempted to just make a small extension loom for this if you need to as it will be hidden above the heater and not noticed.
  • External door handles (unless you can swap these left to right which I can't remember).
#3 prea356m
prea356m
    Starting My Mini Up
  • 2 posts
Posted 25 June 2017 - 07:30 PM
Hi
Thanks for your help . Regarding the pedals  brake clutch and accelerator ???
The RHD steering rack must be a pre 1967 that is obsolete .
You know if is possible to utilize an mkI  post 1967 which is
FAM7306 from minispares and using  the inner column of my MK1 lhd??????????????
I suppose very complicate question
#4 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 20 November 2017 - 01:20 AM
Did the same on a 66 S last year....
The pedal-box with clutch and brake is a straight swap but you will need a RHD gas pedal
You can use any year steering rack and any column will fit.
The carpet is cut differently too
#5 nicklouse
  • 17,945 posts
Posted 20 November 2017 - 01:37 AM
rack needs to match the steering arms.
Also tagged with one or more of these keywords: suspension
