Third Brake Light & Reflective Side Indicators
electrical
14 replies to this topic
#1 peppy
peppy
    Starting My Mini Up
  • 1 posts
Posted 30 September 2017 - 02:40 PM
I'm in the process of importing a 1999 MPI from The Netherlands to Canada.
Two issues I need help with before it passes inspection and gets on the road; there must be something reflective on sides of car and it needs a center mounted third brake light.
Is anyone aware of an aftermarket version of the side indicators on the front wings which is reflective? My lazy option is just to paste reflective stickers on the car sides.
How about a nice center mount brake light which would go inside the car either on the roof liner or mounted on the rear parcel shelf?
thanks for your help
Edited by peppy, 30 September 2017 - 02:42 PM.
#2 GraemeC
GraemeC
  • 7,473 posts
Posted 30 September 2017 - 03:53 PM
There was an original Rover third brake light - might be able to find one of those?
#3 Gillybobs
Gillybobs
  • 243 posts
Posted 03 October 2017 - 07:49 PM
I've fitted one of these to my mini .
http://www.ebay.co.u...WIAAOSwUuFWvCQu
Just stands on the parcel shelf and wired to the brake lights .
#4 Northernpower
Northernpower
    Mr. 7-Port
  • 2,414 posts
  • Name: Graham
Posted 03 October 2017 - 08:20 PM
I've been thinking about one of those, does it not reflect on the inside of the rear window when you brake?
#5 Gillybobs
Gillybobs
  • 243 posts
Posted 03 October 2017 - 08:35 PM
I've fitted one of these to my mini .http://www.ebay.co.u...WIAAOSwUuFWvCQu
Not had this mini on the road with this brake light! Did have a mini before with this type of light and I can't remember it being a problem.
#6 Northernpower
Northernpower
    Mr. 7-Port
  • 2,414 posts
  • Name: Graham
Posted 03 October 2017 - 08:40 PM
If thats the case it could be what I'm looking for. If you have the time after youve got it wired up, I'd be interested to see a pic of the inside of the rear window at night with it working.
#7 Gillybobs
Gillybobs
  • 243 posts
Posted 04 October 2017 - 08:25 PM
Got you a photo . Don't know if this link works for you to see it .
2A1F9AD2-58F7-45E5-9551-FCC87D58BE93_zps
E6F70C04-7488-46FB-B731-FAFDBAA3C8C2_zps
#8 Northernpower
Northernpower
    Mr. 7-Port
  • 2,414 posts
  • Name: Graham
Posted 04 October 2017 - 10:09 PM
Thanks for that. There's nowhere near as much reflection as I thought.
#9 Northernpower
Northernpower
    Mr. 7-Port
  • 2,414 posts
  • Name: Graham
Posted 05 October 2017 - 08:05 AM
Just ordered one.  :proud:
#10 Tornado99
Tornado99
  • 750 posts
Posted 19 July 2020 - 07:46 AM
I have this same LED thrid brake light, but it is a shorter length I I mounted it top edge of window, not parcel shelf.
 Wired it into the brake lights...seems to work fine. But I was just out after dark for the first time since installing and discovered the LED no longer comes on with brakes if the parking or headlight lights are switched on. Normal brake lights still work with parking/head lights. Can't quite understand that.
Any tips on what I should be checking? Is it possibly a polarity issue that changes when other lamps are on?
Edited by Tornado99, 19 July 2020 - 07:48 AM.
#11 nicklouse
  • 19,062 posts
Posted 19 July 2020 - 09:28 AM
Try switching the wires around.
#12 viz139
viz139
  • 727 posts
  • Local Club: Irish Mini Owners Club
Posted 19 July 2020 - 11:10 AM
I think you will find the two wires from your LED brake light joined to the two wires on the back of the light cluster going into the brake light bulb holder. This is wrong, one wire is for the brakes and one is for the parking light. Remove the one from the parking light and join it to the earth /body.
#13 Tornado99
Tornado99
  • 750 posts
Posted 21 July 2020 - 08:47 PM
That does sound how I likely wired it... will check.
#14 Tornado99
Tornado99
  • 750 posts
Posted 26 July 2020 - 07:29 PM
It was incorrectly wired in....as described, the LED ground line was spliced to the rear running light. Now it is on a body panel ground bolt and all is good.
#15 viz139
viz139
  • 727 posts
Posted 27 July 2020 - 09:51 PM
Glad to help
