Verto Clutch Arm Clevis Pin Rusted In
19 replies to this topic
#1 MatthewsDad
MatthewsDad
  • 730 posts
Posted 07 December 2017 - 07:42 PM
Hi, the lower clevis pin on my clutch arm is rusted in. The clutch arm rotates freely, it's the clevis pin that's frozen solid. Have been soaking it for a week with plus gas and hammering it as best I can in the confined space. I don't have access to heat. Has anyone got any suggestions? I'm thinking of grinding off the top of the pin and trying to drift it downwards. Or am I missing something really obvious?
Many thanks
#2 jonlad
jonlad
  • 313 posts
Posted 07 December 2017 - 08:08 PM
Hi, just had the same on a flywheel cover that's been sat for a long long time.
Luckily it wasn't on an engine so i could hold it solid in a vice and give it some welly with a hammer and punch.  there was a fairly hefty step worn into the pin by the clutch lever which really didn't help. Maybe try waggling the clutch lever while tapping in the space that you have?
Or -and i know it'd be a lot of work- take the cover off? Not sure here but maybe you could support the engine on solid wood or jack or axle stands and remove the engine mount and the flywheel cover?
I'm sure somebody will be along to advise if this is possible...
Good luck!
#3 jonlad
jonlad
  • 313 posts
Posted 07 December 2017 - 08:09 PM
Perhaps if you could grind a couple of flats on the head, it might help you turn it and break the rusty bond with the alu cover?
#4 nicklouse
  • 17,945 posts
Posted 07 December 2017 - 08:19 PM
so it is rotating with the arm? or it is stuck in the casing?
or...... it just will not come out?
#5 MatthewsDad
MatthewsDad
  • 730 posts
Posted 07 December 2017 - 10:23 PM
The arm is ok and isn't siezed onto the pin. The pin is siezed solid in the casing.
Grinding flats is a good idea.
#6 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 07 December 2017 - 10:45 PM
The only way you'll be able to resolve this is by cutting the pin(remove the casing to give more space and accuracy)
#7 nicklouse
  • 17,945 posts
Posted 07 December 2017 - 10:56 PM
plus gas will free it up. then rotate 180 degrees and tap it out.
#8 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 07 December 2017 - 11:15 PM
Try a small amount of heat too?
#9 Rorf
Rorf
  • 859 posts
Posted 08 December 2017 - 05:16 AM
Drill the pin out
#10 Magneto
Magneto
  • 889 posts
  • Local Club: KC MINI Club
Posted 12 December 2017 - 01:05 AM
The only way I've had any success getting these out is to remove the cover, be sure to support the boss on the other side from where you're drifting the pin out.
#11 MatthewsDad
MatthewsDad
  • 730 posts
Posted 12 December 2017 - 07:26 AM
Thanks everybody, looks like I'll be spending some time in the garage over the Christmas break. I've got pretty much everything stripped down already.
Problem now is deciding whether to go all the way and deal with the oil seal leak at the same time.
#12 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 15,900 posts
  • Name: Neil
Posted 12 December 2017 - 08:21 AM
Small socket and G clamp. Socket over the the head of the pin and then use the G clamp to force the pin through.
#13 Northernpower
Northernpower
    Mr. 7-Port
  • 2,409 posts
  • Name: Graham
Posted 12 December 2017 - 10:22 AM
If you've got it that far to pieces it's not a lot more work to change out the oil seal and you'll feel a whole lot better when you do. You can also check the clutch at the same time.
#14 MatthewsDad
MatthewsDad
  • 730 posts
Posted 01 January 2018 - 05:31 PM
Just to close out the thread, I've attached a couple of pics of the pin and arm now that they're out - they were in pretty bad shape. Once the flywheel cover was off I cut the head off the pin with a grinder and then drifted it out. Thanks for all the advice.
#15 jonlad
jonlad
  • 313 posts
Posted 01 January 2018 - 07:34 PM
:proud: ​Good work! New parts needed
