Lots Of Simple Questions At Once
#226
Posted 03 January 2020 - 06:09 PM
on the wiper/lights issue. I don't see how I could have it wired wrong because I just connected up the plugs to the various bits. that said i do have an additional loom in the car which moved the dash from behind the wheel to the centre consoul? I've got to take the heater matrix out because it has a slight leak. When that is out it will be a good time to take a look at the wiring under the dash, more room.
Thanks for the help lads.
#227
Posted 15 January 2020 - 10:38 PM
#228
Posted 15 January 2020 - 10:56 PM
I would get some UV leak trace oil additive from guessworks.
give it a good clean up first then add the product then use as normal. Then get the black light out and go all crime scene on it and you will find out where it is not leaking from.
#229
Posted 21 January 2020 - 09:15 AM
I still reckon going through the park circuit, as I set out above, is the way to go. Start at the live on the motor connector (piccy 4 posts up) with a test lamp between a good earth and work your way round the loop to the low speed wire going in to the motor. Be sure to have the ignition key in the appropriate position!
The headlight poltergeist action could be anything from dropping the overall voltage and slowing the motor enough to not override or equalising potential across the motor via poorly grounded earth wiring.
Ethel I've been through the park circuit and can't seem to find an issue. Shame as I was hoping to find a problem. On the subject of the flasher switch, which is more important to me. The wiring diagram shows a purple wire going to the tab in the switch. when you pull the arm towards you it touches this pole and presumably should complete the circuit. The odd thing is that there is also a black wire soldered to the purple one. That would imply its an earth. But you can't have an earth connected to a live feed? The black wire isn't on any wiring diagram. But it does look completely original. I want to wire up some driving lights so I'm trying to sort out these little wiring problems. I'll send this and go and take a picture of the switch.
#230
Posted 21 January 2020 - 10:55 AM
attached is a photo of the flasher switch. As you can see there is a purple and black ??? wire. You can see the post it attaches to with the yellow arrow. The green arrow shows the other side of the switch which is the high beam/dip switch. your thoughts as always much appreciated.
Posted 21 January 2020 - 11:07 AM
by the look of it i'd assume that's non-standard - have you traced the black wire to see what the other end is connecting to ?
#232
Posted 21 January 2020 - 04:54 PM
It looks like its original though which doesn't make sense. I'll try and trace the purple wire back to its source. Looking at the wiring diagram the purple should be live.
#233
Posted 21 January 2020 - 05:13 PM
as far as i'm aware there are very few soldered connections used in a mini - almost all are crimp terminations (presumably as they're a lot quicker to do)
i'd also wonder what's hiding under the insulation tape and heat shrink sleeving in the foreground. both look a bit suspect
the purple wire should be a fused permanent live supply from the fuse box, so you should have 12v to the connector at all times
#234
Posted 21 January 2020 - 05:48 PM
Tony
#235
Posted 21 January 2020 - 05:49 PM
Tony
I wonder if someone wanted a seperate live feed so took it from this point.
#236
Posted 21 January 2020 - 06:14 PM
[quote name="Tonylamb" post="3630622" timestamp="1579628922"]Right so we are pretty confident that the black wire shouldn't be there. I will run a wire from battery to the terminal and see if I get anything. thanks for the thoughts.
Tony
if you trace the black wire back you may find out
#237
Posted 21 January 2020 - 10:50 PM
When the lights are on the lever pushes forward and back between dip and main beam. With the lights off you pull the lever back to flash the lights. In my case that doesn't work. Using the multimeter I was checking the power sources and levered the back part of the switch forward with the probe. The flash mechanism works. Its something to do with the lever action of the brass switch rather than the wiring of it. This is important because I want to use the flash mechanism on the fog lights on the front of the car.
i'm looking for a wiring diagram for the driving lights to come on with the lights on main beam off on dip and to flash. I'm thinking i use the feed to the lights themselves as currently switched to trigger relays for the driving lights.
Thanks for the help and thoughts.
#238
Posted 24 January 2020 - 06:09 PM
#239
Posted 15 February 2020 - 08:42 PM
#240
Posted 03 March 2020 - 09:54 PM
