2000 Cooper Driving Resto
341 replies to this topic
#1 Harryrothers93
Harryrothers93
  • Validating
  • 229 posts
Posted 05 May 2018 - 09:20 AM
After a good few years of not being the owner of a Mini, I have decided to invest in a new (drivable) project
At first look the mini seemed to be perfect from a distance...which we all know is almost never the case.
The list I have put together since purchasing is as followed :
bubbling under front windscreen
slight bubble on right hand side wing where it joins scuttle
oversill fitted
couple of bad floor patches
boot floor has seen better days - will look further in to this when subframe is removed.
rear valance rusted
tired interior
if anyone has any suggestions on the  build then comment all you want.
Harry
Edited by Harryrothers93, 11 February 2019 - 07:01 AM.
#2 Harryrothers93
Harryrothers93
  • Validating
  • 229 posts
Posted 11 May 2018 - 06:01 AM
collecting the mini tomorrow morning, so build / thread can finally start.
first things first I need to sort the battery charging issue - apparently the new alternator output is fine, but nothing getting to the battery.
before I start as anyone got any suggestions? I mean doesn't the cable just go from the alternator to the starter to the battery ? or is it slightly different on an MPI?
any help would be great
more pics to follow tomorrow
#3 jamesquintin
jamesquintin
  • 1,025 posts
Posted 11 May 2018 - 06:22 AM
MPIs can have quite bad earths. The earth strap was moved to the top engine steady. It's probably quite rusty under the bulkhead engine steady bracket. You could can another temporary earth from the engine to the body (there are plenty of bolt holes on the front panel) to get you going
Q
#4 ryomini
ryomini
  • 583 posts
Posted 11 May 2018 - 06:35 AM
If you have time, I think Mini's are worth stripping down completely - derusting and putting back together.  I ported my 1275 spi added a high lift cam and a llightened flywheel and am very happy.  All the best with yours.
#5 Wiggy
Wiggy
  • 1,037 posts
Posted 11 May 2018 - 09:42 AM
Brown/Purple thin wire from alternator, then turns into a thicker Brown cable on the starter. Via a fusible link. It's the one under the shiney black material sheath.
I'd start by removing it at both ends, then checking for continuity.
#6 Harryrothers93
Harryrothers93
  • Validating
  • 229 posts
Posted 11 May 2018 - 04:45 PM
Thanks for replies, will look at earthing and check continuity in morning
Will keep you posted on outcome or if I get stuck
Harry
#7 Harryrothers93
Harryrothers93
  • Validating
  • 229 posts
Posted 12 May 2018 - 10:52 AM
So made a start
Straight away found this disconnected not sure what it does ? Any ideas ? Seems to be space Ona relay above ?
Harry
#8 Wiggy
Wiggy
  • 1,037 posts
Posted 12 May 2018 - 12:03 PM
Think you forgot at attach a pic, mate.
#9 Harryrothers93
Harryrothers93
  • Validating
  • 229 posts
Posted 12 May 2018 - 07:28 PM
update.
found out what the issue was, battery earth was none existent and if you look in the picture there is a taped up connection from the alternator to starter, which was rusted and loose.
Remade off and cleaned up engine earth and battery. now im getting 14.10v at battery which seems about right ?
as for the red cable, does anyone know what that is ?
back at it tomorrow, found a hand sized hole in boot floor and rear valance is just Fu**** so will be in need of some repairs - will upload a picture tomorrow.
#10 Harryrothers93
Harryrothers93
  • Validating
  • 229 posts
Posted 13 May 2018 - 07:15 PM
pictures of boot floor hole and bad patch job...
the whole boot floor really isn't much better than this so will be replacing the full thing instead of trying to patch.
when I get the back end up on axle stands I will upload more photos.
replacment won't be for a few months as I am going to enjoy driving her about for a while until i start chasing rust.
plan is to take a week of work in July and do the whole back end in one
-bootfloor
-rear valance
-arches
-rebuild subframe
harry
#11 Harryrothers93
Harryrothers93
  • Validating
  • 229 posts
Posted 15 May 2018 - 02:05 PM
got some spare time on my lunch break today
I removed the front spot lights - I think it looks 10 times better without ....?
fitted a rubber trim strip between the grill moustache and front panel, just to stop it from scratching paint
I also tidied up the engine bay slightly with a rag and wd40.
new plugs and leads fitted - ignition leads are from a guy on ebay who hand makes them to order, overall seem very good quality.
will get the oil changed when I next get chance, anyone have any suggestions on oil ?
harry
#12 Harryrothers93
Harryrothers93
  • Validating
  • 229 posts
Posted 29 September 2018 - 07:17 PM
long time without an update so here goes.....
I have done quite a lot since the last update and the mini does look...
..well lets just say when its all done it will be worth it !
best way I think I can show the progress is by uploading all the rust found and then the repairs, so here you go.
inner wings look ok, just lower part and shock mounts to fix
Attached File  fullsizeoutput_4c1.jpeg   42.25K   2 downloadsAttached File  fullsizeoutput_681.jpeg   32.66K   3 downloads
Attached File  fullsizeoutput_689.jpeg   51.45K   2 downloads
boot floor is way past fixing would end up being a patch quilt
Attached File  fullsizeoutput_4d2.jpeg   91.29K   2 downloadsAttached File  fullsizeoutput_4da.jpeg   49.6K   3 downloads
rear seat bulkhead has also seen better days along the bottom edge
Attached File  fullsizeoutput_4e0.jpeg   90.09K   2 downloads
comments more than welcome
Edited by Harryrothers93, 03 March 2019 - 09:01 AM.
#13 Harryrothers93
Harryrothers93
  • Validating
  • 229 posts
Posted 29 September 2018 - 07:23 PM
The left side rear arch was about 30% metal 70% filler so that had to go
Attached File  fullsizeoutput_4e8.jpeg   61.01K   1 downloads
at the front end the scuttle will need replacing along with the inner dash rail. mainly because the person who did the previous repair on the bulkhead did not treat the inside and just lapped the metal
Attached File  fullsizeoutput_691.jpeg   34.78K   3 downloadsAttached File  fullsizeoutput_699.jpeg   34.15K   3 downloads
Edited by Harryrothers93, 03 March 2019 - 09:14 AM.
#14 Harryrothers93
Harryrothers93
  • Validating
  • 229 posts
Posted 29 September 2018 - 07:28 PM
#15 Harryrothers93
Harryrothers93
  • Validating
  • 229 posts
Posted 29 September 2018 - 07:37 PM
so after finding all that rust and with not even looking into the front end as yet. I went ahead and bought myself a new mig welder
after researching what seemed like the entire internet I decided to go with a R-tech welder, and I must be honest its one proper good machine !
Attached File  fullsizeoutput_69f.jpeg   48.67K   1 downloadsAttached File  fullsizeoutput_6a5.jpeg   56.1K   4 downloadsAttached File  fullsizeoutput_4f0.jpeg   33.67K   9 downloads
Edited by Harryrothers93, 03 March 2019 - 09:22 AM.
    Bing (2)
