2000 Cooper Driving Resto
341 replies to this topic
#331 sonscar
sonscar
  • 3,243 posts
Posted 28 May 2023 - 08:54 AM
Can you hear the fuel pump prime briefly when you turn it on without cranking?Have you checked for spark?,Steve..
#332 Harryrothers93
Harryrothers93
  • Validating
  • 229 posts
Posted 28 May 2023 - 04:04 PM
The fuel primes fine. And have spark at all 4 plugs
Any other ideas 😅
Like I say I have had it started but it’s so inconsistent something has to be either breaking down or faulty…
Just not sure on next step
#333 Harryrothers93
Harryrothers93
  • Validating
  • 229 posts
Posted 28 May 2023 - 04:07 PM
Could anyone give me the exact Ht lead order
My seems to think it’s different to how I have it
And looking at images online of MPI minis they vary from 1 on the coil (bottom front) going to either spark plug closet to alternator or brake master cylinder
Any way in on this would be good
Be great to complety rule out firing order
#334 pete l
pete l
  • 1,528 posts
Posted 28 May 2023 - 04:22 PM
The MPI has a wasted spark ignition system. Which means 2 sparkplugs fire at the same time. There are a number of different ways to wire them up.
#335 sonscar
sonscar
  • 3,243 posts
Posted 28 May 2023 - 04:50 PM
Look at the coil,it is likely to be numbered,Steve..
#336 Harryrothers93
Harryrothers93
  • Validating
  • 229 posts
Posted 28 May 2023 - 07:49 PM
Ok guys.
New plugs and found a pic of how the HT leads were originally before rebuild and she starts on first crank a runs sweet
New problem
She over heated within 5 mins
Temp gauge climbed high super quick
Fan did not kick in though
Now she did have coolant say in her for a while last year with zero motion
Any chance the radiator could be blocked?
Doesn’t explain the fan not coming on
But she shouldn’t get that hot that quick
The top coolant hose that passes over the spark plugs was hot
So I’m guessing some coolant is passing through and the pump is doing it’s job etc
But again one problem fixed another shows it’s face!
#337 Harryrothers93
Harryrothers93
  • Validating
  • 229 posts
Posted 28 May 2023 - 08:35 PM
Does anyone know what the purple with red strip cable does on left front behind grill
Currently goes no where…
#338 Harryrothers93
Harryrothers93
  • Validating
  • 229 posts
Posted 28 May 2023 - 08:36 PM
Edited by Harryrothers93, 03 June 2023 - 06:37 AM.
#339 Harryrothers93
Harryrothers93
  • Validating
  • 229 posts
Posted 02 June 2023 - 05:18 PM
Ok so update on this
I have replaced thermostat, temp sensor (again) new radiator fit and system flushed.
She now doesn’t over heat and bubble at expansion tank
Fan still doesn’t come on through standard spec
And I narrowed it down to the actual feed cable to the fan
So somewhere in the loom it’s damaged
I have opted for a stand alone digital temp sensor fitted on top radiator pipe to switch fan on and off and disconnected old
This has completely sorted the over heating issue and the mini ran for a good 20mins and then stopped and won’t start again
The fuel pump is not priming now
Fuse ok
No power at inertia switch
I am currently working back until I get power
And cleaning up the earths on mini as the earth argument behind the expansion tank was crazy dirty in terminals
Can any one tell me if that earth had anything todo with the immobiliser? As I’m starting to think that might be my issue, the relay pack for fuel pump isn’t clicking like it used to
One question I wanted to know is can I put my fuel pump on a override switch or will this mess with the ecu in some way?
#340 Harryrothers93
Harryrothers93
  • Validating
  • 229 posts
Posted 03 June 2023 - 06:30 AM
https://imgur.com/ZzU7Zlk
any idea on this ? Faulty /bad Earth maybe
the relay clicking behind dash is far left, this also clicking while trying to start but no turn over
ever so often il get it to crank by pressing fob but fuel pump doesn’t prime etc
Edited by Harryrothers93, 03 June 2023 - 06:33 AM.
#341 Harryrothers93
Harryrothers93
  • Validating
  • 229 posts
Posted 03 June 2023 - 06:34 AM
engine bay so far
Edited by Harryrothers93, 03 June 2023 - 06:35 AM.
#342 Harryrothers93
Harryrothers93
  • Validating
  • 229 posts
Posted 05 June 2023 - 06:17 PM
Sorted this now guys!
was actually a combination of two issues
Fuse was ok but turned out one of the terminals had grime on it so wasn’t making proper contact
Also changed fob Battery and reset immobiliser
All working fine now just have the gear selector seal to change and run brake lines
    Bing (2)
