Rod Change Length
4 replies to this topic
#1 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 11 November 2018 - 08:17 PM
Hi,
Doing a 998 auto to 998 manual conversion and am collecting all the parts.
I have an engine etc and the rod gearchange linkage.
How do I know that the rod length is correct?
I can't be sure what type of rod change I have -
original length?
1/2 inch longer from when the 1275 was moved forward?
Metro rod change? (is a metro one any different?)
Obvious way is to measure the steady rod and gear select rod, but can anyone tell me the lengths they should be?
Or - is there an easier way to identify?
Edited by jime17, 11 November 2018 - 08:18 PM.
#2 nicklouse
  • 19,067 posts
Posted 11 November 2018 - 08:27 PM
metro has a different body bracket and is longer than the others.
#3 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 11 November 2018 - 08:39 PM
Ok thanks Nick.
It has the mini mounting bracket so that's good.
How can I tell if it's a regular length or the mpi longer one?
It has the round gear knob with the round plastic insert so my hunch is it's older but I'd like to be certain before I start.
It's my first project of this kind so I'm a bit unsure about lots of things.
Edited by jime17, 11 November 2018 - 08:52 PM.
#4 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 11 November 2018 - 09:16 PM
The steady rod for the later model subframe (1/2" forward)had a slot on one side and a hole on the other and the earlier one had 2 holes. The thread below has dimension on it too.
http://www.theminifo...ting-silly-now/
#5 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 11 November 2018 - 09:40 PM
Just checked mine.... 2 holes in the steady bar end so fingers crossed.
Edited by jime17, 11 November 2018 - 09:41 PM.
