That's very useful thankyou. What kind of pressure pump are we talking about. 50 psi?
Also I cant get the calculator to work?
I've edited the link, it should now work. As far as the fuel pump pressure is concerned the SC kit is designed to be regulated to 3.5 bar so you're looking for a pump with a greater delivery. If you're using a mini fuel tank the MPI (not SPI) is sufficient. If you're running a different type of pump don't forget a quality inline filter between the tank and the pump. Of equal importance is the feed from the pump to the injection rail. Regardless of whether you place the regulator in the boot or the engine compartment you need to use a quality fuel line and given the poor quality of some of the flexible lines out there a rigid line (copper) is the best bet. If you haven't wired it up yet don't forget the SC ECU controls the fuel pump earth not the live feed.
