Ok, thanks for your help everyone!
So the the rear ones are pretty self explanatory but how do you know how much to cut of the front?
Posted 07 March 2019 - 07:30 PM
Posted 07 March 2019 - 07:32 PM
And one more thing, after tubbing, do you raise the arch so that the lowest part of the arch is level with the metal fender?
Like so that if i hit a bump, that it would hit the metal not the fiberglass arch....
Posted 07 March 2019 - 07:56 PM
Posted 07 March 2019 - 07:59 PM
Posted 07 March 2019 - 08:14 PM
if this helps this picture shows the fitment i am going for...
sorry, this is my first mini, i know the look i am going for but don't have the knowledge and experience so your help is much appreciated!
Posted 07 March 2019 - 08:24 PM
You need to fit the suspension and wheels but without rubber cones or shocks then move the wheel through its full travel up and down to the bump stops with wheels turned left and right, if it can hit then it can hit when in use.
I'd add at least another 1/4" for flex and tire expansion.
Posted 07 March 2019 - 09:35 PM
so sorry for all my lack of knowledge...
but using this picture can someone tell where is the best place to cut the metal in relation to the arch?
Posted 07 March 2019 - 09:36 PM
that helps thanks!
Posted 07 March 2019 - 11:25 PM
lowered at the front cut wings. standard rear.
Posted 07 March 2019 - 11:26 PM
from the pictures you have shared dont need any tubbing as they have been standard rear.
Posted 07 March 2019 - 11:31 PM
you cut whatever is needed for your set up. i only trimmed the front of the wing/front panel area as that is what the tyre caught on. if you are not changing the upper shock mounts the internal bumpstops generally stop wheels hitting the metal. but again it all comes down to what you build and want.
Posted 08 March 2019 - 01:15 PM
So now i am confused about the rear because i am getting different answers
Posted 08 March 2019 - 01:26 PM
i will be using hi los and lowered adjustable shocks, does that change or reduce the wheel travel?
Posted 08 March 2019 - 01:30 PM
Posted 08 March 2019 - 02:30 PM
another picture i found just for good measure showing what look i am going for
Mini Technical Sections →
Problems, Questions and Technical →
Mot Advisories On Potential PurchaseStarted by billlifferr , 12 Jun 2023 suspension |
Fitting 10” Wheels On My Mini Convertible (Spi)Started by Dalla , 29 May 2023 suspension, brakes |
Radius Arm - Reaming Or Beyond Repair?Started by Chelsea_Pete , 04 May 2023 suspension |
Correct Upper Suspension Arm Tightening Process?Started by Dakinn , 03 May 2023 suspension |
Track Rod End Thread Engagement / Adjustable Lower ArmsStarted by YankWithAMini , 02 May 2023 suspension |
