Engine Whining Noise
24 replies to this topic
#16 unburntfuelinthemorning
  • 1,915 posts
Posted 14 September 2019 - 07:30 PM
See if this helps
#17 Sam Biscuits
Sam Biscuits
  • 31 posts
Posted 14 September 2019 - 08:01 PM
Thanks guys, will get back to it tomorrow. Anyone know if there should be a ground attached to a bolt on the left side of the alternator? It looks like there should be but there isn't.
#18 unburntfuelinthemorning
  • 1,915 posts
Posted 14 September 2019 - 08:39 PM
The alternator earths through the engine block.
#19 panky
panky
  • 1,777 posts
Posted 14 September 2019 - 10:21 PM
How about taking the fan belt off so the alternator is isolated and do a (very) quick run. If the noise goes then there's the culprit.
#20 Sam Biscuits
Sam Biscuits
  • 31 posts
Posted 15 September 2019 - 09:14 PM
I put an iPod in to the amp input, noise still present, so that rules or the head unit and the RCA cables. I can hear the noise on the speakers on the alternator when running, should it run silently? Too much tension on the belt?
#21 viz139
viz139
  • 569 posts
  • Local Club: Irish Mini Owners Club
Posted 16 September 2019 - 03:24 PM
Belt tension and alternator bearings are mechanical noise you hear at the engine . The next thing I would do is run the engine without the alternator connected to ensure the interference isn't coming from the ignition. If it is clear and you have already changed the amp I would look at replacing the alternator.
#22 Sam Biscuits
Sam Biscuits
  • 31 posts
Posted 16 September 2019 - 04:06 PM
Ugh, I hope I don’t have to replace the alternator, it’s less than a year old and probably has only done a few hundred miles! I will run the engine without it and see how it sounds.
#23 Sam Biscuits
Sam Biscuits
  • 31 posts
Posted 22 September 2019 - 12:06 PM
Finally figured out the problem with this, turns out it’s been the head unit all along. Put my original head unit in, no noise anywhere. So to fix it , it’s either a new wiring harness (old head unit has different socket which I plug in to am adapting harness to then plug in to the new one), or I will try and ground the RCA sockets on the back of the new head unit. Grounding the sockets won’t look pretty, but it’s only temporary until I get around to getting an Apple Car Play head unit.
#24 unburntfuelinthemorning
  • 1,915 posts
Posted 22 September 2019 - 03:23 PM
Glad you're getting somewhere with it.
#25 Sam Biscuits
Sam Biscuits
  • 31 posts
Posted 22 September 2019 - 05:49 PM
Fixed it at last. Turns out grounding the RCA sockets on the head unit was the answer.
