out of interest, do you machine the housing, or just skim it on some wet & dry?
Oil pump endfloat is as Nicklouse stated. Aim for 0.003" on the oil pump.
Ac
Posted 05 December 2019 - 10:32 AM
Ac
Posted 05 December 2019 - 10:35 AM
Ac
AC uses a lathe.
I being a home garage person use wet and dry on a sheet of glass (wet).
it comes down to what you have to work with.
you can guess which is the right way to do though.
Posted 05 December 2019 - 10:40 AM
Good Answer,
I guess i knew that really from AC's attention to detail... but i was thinking is it quicker to just do it like you do rather than clock it up
Posted 05 December 2019 - 10:48 PM
Posted 05 December 2019 - 10:57 PM
Posted 05 December 2019 - 10:58 PM
see Above.
Edited by nicklouse, 05 December 2019 - 10:59 PM.
Posted 06 December 2019 - 06:54 PM
Posted 06 December 2019 - 07:13 PM
Posted 06 December 2019 - 08:08 PM
Could you expalin how this reduces the end float? I am probably just being thick but the way you describe would mean for example...
When the camshaft is moved towards the back on the engine its o.ooo" and then when the camshaft is slid towards the front there's 0.011".
So if the camshaft end float is retained by the oil pump and the cam retaining plate I dont understand how the camshaft end float is reduced by skimming the cam sprocket by 0.006"...
NO. The oil pump has nothing to do with the camshaft endfloat. You can set the cam endfloat without the pump fitted.
Posted 07 December 2019 - 01:21 PM
Posted 07 December 2019 - 01:29 PM
Posted 07 December 2019 - 03:08 PM
Recheck the cam end float after fitting the pump as it has been known for the pump drive to bottom out in the drive slot in the cam.
That tends to be on faulty made cams though.
Posted 28 August 2020 - 03:26 PM
Resurrecting my old thread here, yes its been over 8 months and I am now at the stage where I need to check the Camshaft End Float.
I am still not quite sure of the process whether or not you need to have the Oil Pump on or not when doing this, as they should not affect each other. And I cannot find anywhere that explains how to lift the Cam Sprocket to check?
With the Oil Pump fitted (no gasket), and the bolts done up the pump is solid.
I have fitted the Cam and Crank Timing Sprockets and they appear to be level with no shims fitted. (New Cam Sprockets and Chain (EVO Duplex).
With the Cam Lock Tab on and Nut done up (not Torqued), if I lift then Sprocket using my hands I get 0.005" on the DTI gauge, which, according to the Rover Repair manual is with tolerance (0.003" - 0.007".
If it needs to be Torqued on - how do you hold the CamShaft?
What is the correct way of lifting the Cam Sprocket?
Edited by JonnyAlpha, 28 August 2020 - 03:29 PM.
Posted 28 August 2020 - 03:33 PM
The chain hold the cam sprocket. The gears should be checked with the cam pulled forward.
Posted 28 August 2020 - 04:33 PM
What do you mean ‘pulled forward’?The chain hold the cam sprocket. The gears should be checked with the cam pulled forward.
Edited by JonnyAlpha, 28 August 2020 - 06:07 PM.
