Rear Subframe Mounts Rusted On..
14 replies to this topic
#1 Bdshim
Bdshim
  • Just Joined
  • 196 posts
Posted 01 January 2020 - 03:59 PM
Ither side when the subframe mounts to the heal board a two bolts have snapped in the hole one itherside I'm thinking of trying to drill these out as I tried sliding the subframe off the remaining broken bolt but I think its rusted around the bolt and eont shift. I would get a photo up but my hosting site is playing up any advice tips would be appreciated.
Thanks ?
#2 Wreckitralph1
Wreckitralph1
    Formally known as wreckitralph
  • 127 posts
Posted 01 January 2020 - 05:35 PM
i had the same i cleaned with a wire brush then wd40 then used a small pry bar between the sound heelboard and subframe as close to the bolts as i coud and then the opp side and poyt it came
#3 Bdshim
Bdshim
  • Just Joined
  • 196 posts
Posted 01 January 2020 - 06:09 PM
I have been soaking in wd40 last few days il try that tommorw thank you
#4 gazza82
gazza82
  • 3,099 posts
  • Local Club: TMF+
Posted 01 January 2020 - 11:19 PM
Try a better penetrating fluid ... wd40 is just a lubricant
#5 Bdshim
Bdshim
  • Just Joined
  • 196 posts
Posted 02 January 2020 - 08:11 AM
#6 JonnyAlpha
JonnyAlpha
  • 2,749 posts
  • Local Club: Exmoor Minis
Posted 02 January 2020 - 08:53 AM
PlusGas
https://www.amazon.c...l/dp/B0001P02RK
#7 MiniMadRacer
MiniMadRacer
  • 906 posts
Posted 02 January 2020 - 10:05 AM
At your own risk  - I have used a blow lamp (carpets out of the back of the car obviously and remove any trim form the side bins - preferably have a mate inside the car keeping an eye on things), heat the bolt / stud up and then protecting your face, spray from a 12 inch or so distance penetrating fluid on the stud.  The thermal shock shrinks the stud, often breaking the rust seal and as the stud instantly cools it sucks the penetrating fluid around the threads - Be very very careful though that the fluid doesn't spit and hit you in the face as it hits the stud.. I always where a full space grinding mask when doing this... and keep water / extinguisher within arms reach.. best to remove fuel tank too as a precaution
#8 sonscar
sonscar
  • 3,254 posts
Posted 02 January 2020 - 11:17 AM
Lever a small gap between the heelboard and fixing then using a suitably protected hacksaw blade cut through it.Then try drilling out the bolts.Steve..
#9 DeadSquare
DeadSquare
  • 3,382 posts
Posted 02 January 2020 - 12:29 PM
Lever a small gap between the heal board and fixing then using a suitably protected hacksaw blade cut through it.Then try drilling out the bolts.Steve..
If you can lever a gap, then, by tapping it back and forth it should loosen up and come off.
Welding a nut on to the snapped bolt close to the heal board gets a lot of heat into the captive nut inside.
#10 Bdshim
Bdshim
  • Just Joined
  • 196 posts
Posted 02 January 2020 - 02:16 PM
Thanks for the suggestions much appreciated it's still not currently moving il keep you posted ?
#11 DeadSquare
DeadSquare
  • 3,382 posts
Posted 02 January 2020 - 03:20 PM
If you are lucky, (unlucky), the set screws twist off at the head, and it is possible to drill an 1/8th" hole between the top of the. 'now stud', and the mount;  this lets the easing fluid along the length of the thread.
#12 Bdshim
Bdshim
  • Just Joined
  • 196 posts
Posted 03 January 2020 - 03:05 PM
Success! I managed to slide a hacksaw blade in a slowly cut the bolt thank you for all the suggestions, imageshack is still being a pain il get some photos up soon.
#13 Bdshim
Bdshim
  • Just Joined
  • 196 posts
Posted 03 January 2020 - 03:08 PM
<a href="https://ibb.co/m9WHV7C"><img src="https://i.ibb.co/k4C...-054525-213.jpg" alt="IMG-20191230-054525-213
#14 area51
area51
  • 42 posts
Posted 05 January 2020 - 10:31 PM
I’ve just finished replacing one side, it’s not a pleasant job, the other side I managed to drill out very successfully
#15 bpirie1000
bpirie1000
  • Area Managers
  • 2,565 posts
  • Local Club: Amoc
Posted 06 January 2020 - 03:43 AM
If you can get the frame off try welding a nut to the studs.. saves so much time also heat is great idea.
