1969 Mk2 Cooper
101 replies to this topic
#31 sonscar
sonscar
  • 3,257 posts
Posted 27 March 2020 - 07:39 AM
I found it difficult to remove the rusty clutch hose.With the motor out and some big spanners it undid.Steve..
#32 blacktulip
blacktulip
  • 6,231 posts
Posted 28 March 2020 - 01:05 AM
As no work tomorrow i managed another few hours tonight. Got the engine out as i want to see why it was knocking and juddering so much. I found the culprit
Broke engine mount
Engine out!
I'm amazed at the condition of this original exhaust manifold is. It's very solid and the welds are as good as ever.
With the broken engine mount I would say the clutch is probably good but I think maybe I should change it whilst it's out. Hopefully that rules out a bearing failure too. The oil pressure was bang on. I've also got some bmc green paint coming.
One grotty engine bay that needs sprucing up....
One original 998cc cooper engine (except the later rockers)...
One drive coupling that's seen better days...
Anyone fancy some syrup? It's actually as thick. It took ages to drain out...
On to tomorrow....
Edited by blacktulip, 28 March 2020 - 01:12 AM.
#33 Daz1968
Daz1968
  • 2,058 posts
Posted 28 March 2020 - 08:24 AM
The exhaust manifold is not original Cooper one, but main thing it’s design is not the best, I fitted a free flow maniflow to mine along with twin box rc40. Original manifold is pressed steel with external seams on pipes. Engine mounting well past it though, it’s good when it’s an easy fix.
#34 blacktulip
blacktulip
  • 6,231 posts
Posted 28 March 2020 - 11:14 AM
That manifold is going then ? do you reckon it's from a morris minor of something?
#35 Daz1968
Daz1968
  • 2,058 posts
Posted 28 March 2020 - 04:16 PM
Looks like a budget aftermarket one to me due to how pipes are joined
#36 blacktulip
blacktulip
  • 6,231 posts
Posted 29 March 2020 - 11:57 PM
Oh problems oh problems. Went to take the clutch off today and the flywheel is stuck. The threads on the flywheel are buggered. I got some good heat on there as well but as soon as I got some good pressure on the nut it pulled a bolt. The bolts were brand new too. Not sure what to do. Should I tap a new metric thread? The fylweel is going in the bin anyway as the ring gear is worn out.
#37 sonscar
sonscar
  • 3,257 posts
Posted 30 March 2020 - 09:17 AM
I had the same happen and tapped new bigger threads.I used metric as the local bolt supplier only stocks metric.I had to file bigger the holes in the puller.I may have just committed a sin using metric on a Mini.Steve..
#38 blacktulip
blacktulip
  • 6,231 posts
Posted 31 March 2020 - 07:15 PM
Right.... so retapped m10 threads. Vernier calipered the distances on each bolt so the same. Got good pressure on the nut... wish me luck. Came in for a cup of tea...
#39 imack
imack
  • 2,382 posts
Posted 31 March 2020 - 07:42 PM
Have you greased the bolt thread on the puller? It looks pretty dry in the photo.
#40 johnR
johnR
  • 2,324 posts
Posted 31 March 2020 - 07:57 PM
Lovely project, looks to be in really good condition. What's the interior like?
#41 blacktulip
blacktulip
  • 6,231 posts
Posted 31 March 2020 - 08:37 PM
Thanks mate. All there in good condition too ?
#42 blacktulip
blacktulip
  • 6,231 posts
Posted 31 March 2020 - 08:39 PM
Only the end of the bolt which is in the crank buffer as per instructions in the kit. I will release and grease now and see if it helps. Cheers for that
#43 blacktulip
blacktulip
  • 6,231 posts
Posted 31 March 2020 - 09:23 PM
It's off!! Thank God for that. Cheers for the advice guys!!
#44 blacktulip
blacktulip
  • 6,231 posts
Posted 02 April 2020 - 11:19 PM
Started to clean the grime of of the engine. It's nice to see the original plate still attached. I did a schoolboy error as I wanted to undo the timing bolt to get the cover off as there looks to be no gasket there but now i have got the flywheel off I have nothing to lock the crank up with now. So I will have to get that side done first before doing the other. The picture at the bottom... I know the bolt is loose. I did it ?
Edited by blacktulip, 02 April 2020 - 11:21 PM.
#45 Daz1968
Daz1968
  • 2,058 posts
Posted 02 April 2020 - 11:47 PM
Looking good, if you haven’t already got them use the qh type nylon needle roller type driveshaft couplings when you refit engine rather than the rubber ones.
