Wheel Bearings
24 replies to this topic
#1 Jewson16
Jewson16
  • 14 posts
Posted 21 March 2020 - 05:11 PM
I'm replacing all the wheel bearings to the mini I'm restoring (front are disks back are drums) just wondering what everyone will recommend
#2 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 21 March 2020 - 05:40 PM
Timken's, not worth bothering with other cheaper ones. I've bought minispares Rear bearings, done about 500 miles and it locked up solid when I was doing 60mph and needed a new radius arm, hub and tyre.
#3 Spider
  • 15,873 posts
Posted 21 March 2020 - 05:41 PM
Timken every time.
I have tried nn genuine a while back and got very poor life from them, the best being around 5000 km. Thing is when they fail, they can damage other parts, ie, CV and Hub, so it may not just be a case of buying another cheap bearing.
#4 Jewson16
Jewson16
  • 14 posts
Posted 21 March 2020 - 07:42 PM
That's what I was thinking don't think a cheap bearing would do I've head they're unreliable so Timken it is.Thanks everyone for your help ?
#5 unburntfuelinthemorning
  • 2,003 posts
Posted 21 March 2020 - 08:35 PM
Another belated vote for Timken.
#6 MatthewsDad
MatthewsDad
  • 903 posts
Posted 22 March 2020 - 09:54 AM
Did you report that back to minispares? They would surely need to do a recall if a batch of bearings was found to be faulty?
#7 Rorf
Rorf
  • 866 posts
Posted 22 March 2020 - 10:48 AM
Doesn't matter what make of bearing one installs, if the stub nut when torqued up to the correct spec prevents the wheel from turning easily or the bearing is too loose then the bearing will eventually fail.
Another factor which causes over heating bearings is putting too much wheel bearing grease in the hub.
#8 jimmini
jimmini
    Starting My Mini Up
  • 4 posts
Posted 30 March 2020 - 09:09 PM
Hi!! sorry to hijack the thread...
My bearings are going to need replacing pretty soonish, whats grease can people recommend to use when I come to do it. A quick google has come up with some conflicting suggestions. Just wondering if anyone had a favourite :D
#9 unburntfuelinthemorning
  • 2,003 posts
Posted 30 March 2020 - 09:28 PM
I just use the grease that Minispares sell.
#10 Spider
  • 15,873 posts
Posted 30 March 2020 - 09:55 PM
I was using Castrol for many years, but recently, it seems to have too much water in it.
I swapped over to Timken's Grease a few years back and I've found it superior to Castrol's even when it was good !
#11 no66
no66
  • 156 posts
  • Local Club: NMCC (Norsk Mini Cooper Club)
Posted 31 March 2020 - 08:58 AM
Timken, Nachi or NTN.
#12 mickyh
mickyh
  • 391 posts
  • Local Club: not yet
Posted 08 April 2020 - 09:29 PM
Now tried mini sport genuine bearings, and when torqued up the wheel is very hard to move; surely it can’t be the bearings; any ideas, hubs or shaft?
#13 Spider
  • 15,873 posts
Posted 09 April 2020 - 01:38 AM
Check everything, but almost certainly, it will be the Bearings.
#14 Rorf
Rorf
  • 866 posts
Posted 09 April 2020 - 05:15 AM
What is a MiniSport genuine bearing? Obviously a No Name Band :lol:
#15 cian
cian
  • 869 posts
  • Local Club: Minis In Northern Ireland
Posted 09 April 2020 - 05:22 AM
I have a full stock of timken front and rear bearings, nos
