Dying Electrics For Signals , Horn, Emergency Breakdown Lights , Lights ...
6 replies to this topic
#1 Zippster1977
Zippster1977
  • 64 posts
Posted 20 May 2020 - 10:20 AM
Hi
My electrics for signals, lights , horn has always been ropey but successfully always managed to get through its MOT for years . Given I’ve got a lot of free time , I’m going to butch trying to fix it all . Any tips on how to get the whole lot rewired?! And what to buy ?
I have a 1989 mini . Thanks
#2 MiddletoM
MiddletoM
  • Just Joined
  • 60 posts
Posted 20 May 2020 - 10:50 AM
First i would remove the main fuse box and clean all the connectors, then i would remove the steering column cowling and lightly clean the contacts for the switches for the full beams. This will likely solve the vast majority of the issues.
#3 KTS
KTS
  • 2,490 posts
Posted 20 May 2020 - 11:11 AM
one option - if it's right for your car.  Would need overhauling before being fitted though, unless you're feeling lucky  ;D
http://www.theminifo...m-for-sale-£40/
#4 Zippster1977
Zippster1977
  • 64 posts
Posted 20 May 2020 - 11:32 AM
Thanks heaps for your feedback and time ...
is it worth getting a new piece of the below ?
#5 Zippster1977
Zippster1977
  • 64 posts
Posted 20 May 2020 - 11:35 AM
Ive cleansed the fuse box and connectors already , but thanks for the tips !
#6 mab01uk
mab01uk
  • 13,092 posts
Posted 23 May 2020 - 08:54 AM
Common fault and usually the fuse box but you need to clean the back of it up or best to replace. Take a photo/make notes/label all the wires on the fuse box, take it off the car and give the back a good clean, and use a wire brush to clean all the contacts. Make sure you put all wires back where they're supposed to be. Ideally replace the fuse box with a new one.
There are many cheap copies on the market but this is the real thing from Minispares:-
https://www.minispar...ic/RTC440A.aspx
You might find this old thread of interest:-
http://www.theminifo...ake-lights-etc/
#7 surfblue
surfblue
  • 1,829 posts
Posted 24 May 2020 - 06:07 PM
Poor earth connections are responsible for lots of misbehaving electrics, make sure all earthing points are clean, rust free and apply a little grease or vaseline over them.
