When I did work at Ford (a loooong time ago !) the engines they were fitting in the cars they were assembling at that plant were CKD from Japan (there were sold here as a Ford Lazer and were a re-badged Mazda 323), they would running them for around 1 minute on a rolling road at one of the very end stations on the line, then they would take the car out to their test track and do 1 lap. Every car off the line went through this.
Back in the days they were doing the Escorts, the 'Sports' models that were fitted with side draft Webers were subject to two laps as they had issues from hot flooding.
In our local BMC Factory, every engine as it was completed and before fitting was ran for an hour on the engine dyno until fuel costs went up and this was reduced to 20 minutes.
I note that in all new cars, the owners manual always provides some advice as to correct running in procedures. Some seem to suggest as little as 300 miles and others, like say our Holden SSV Commodores had a 3000 mile Run In. I think to, the Ford Mustangs are similar.
Mhale, say it takes 3000 miles for rings to fully run in and I'd agree with that, however, they only need to follow a procedure for the first 300 - 800 miles.
I stress as I said earlier - this is not always a 'one size fits all.
I think maybe a step back here might be in order and look at what is actually going on during this break in / running in period to understand what's happening and it might shed some light as to why this is done.
Considering here first the Rings and the Bore. As many things that have been written and mentioned, these have high and low spots on their mating faces on both the rings and the bores, but, also, the Bore has (or should have !!) a Honed finish.
Depending on the shop and how they may do the honing will also have a lot to do with running in and how long it takes.
I did a write up on this a few years back http://www.theminifo...gine-machining/
Some shops bore and leave 0,001" for honing as they can get the job out quicker, but,,, I can't see how that will remove all the 'marks' from boring. I leave 0.003" so I can clean the bores up,, then hone them with a grit to suit the rings, finally, I plateau hone the bores with is a very fine hone and this 'knocks the tops off' the finish honing. This can allow for a quicker running in, but, from what I've seen, few shops will do this as it's another step and more time for them.
In running in, we are 'mating' the rings to the bores.
Keep in mind here too that the rings are lubricated by the Oil that's left in the honing and should be no more and no less.
How does the Oil get on the bores ? There's no direct oiling of the bores (of course!) and so the only oil they'll get is what's flung up off the Big Ends as the engine spins. If it spins slow, there's little oil being pumped and little being flung off the big ends. Not a lot of oil is needed here as much should be wiped by the Oil Control Rings and these should leave a metered amount of oil in the honing for the rings. Cold Oil doesn't lubricate nearly as well as hot oil and is also a lot thicker and 'harder' to wipe away. Also, metals, like steel and cast iron will absorb oil, but when fresh machined or ground (in particular) are 'reluctant' to absorb anything, until they are heated and while that's occurring, to avoid scuffing, they need to be well drenched with hot oil.
In running, the engine bores flex, the rods (especially our off-set types) 'bend', the Pistons flex and the Rings are subject to a huge range of temps and pressures from extreme Negative to high Positive pressures. These all change with Revs and Load, yet we expect - demand !! - that they seal 100% under all these conditions and also keep Oil consumption low to very low.
We've all done some sanding at one time or another. If we sand back body filler, it's easy to make fast progress and likewise, if we sand steel, progress is slow. Why ? Largely because the body filler is soft and the steel is hard. Also, there's a fair bit of heat made by this abrasive process. If we use more pressure, the rate at which material is removed is also faster and there's more heat made.
Some engine builders will fit fit a softer ring so they bed in fast. Great if you need to get on the race track in the morning, but, as mentioned above, being softer, it will wear faster. Likewise, usually temps at the ring faces are higher.
There's more to it than just this simple analogy, but one might be able to see why a fast break in also leads to a fast wear out.
I was showed a set of rings that came from a fresh built engine that came with the advice 'drive it like you stole it' to break it in. It smoked in short time and the rings were so soft, you could tie knots in them, Zero tension in them !
I've also hinted here in what's happening with breaking in Cams and Followers. These are steel and should have a ground finish. Fresh Ground steels don't absorb oil too well. The Camshaft Lobes are only lubricated also from the Big Ends. I have seen and fitted Cams that have a through drilling for Oil to be fed directly in to the Lobes, however, have a long think about what action is occurring here and you'll soon work out that while this does help, it's not doing a lot at all and it won't save the Cam Lobes and followers if there is a lubrication issue.
Breaking in of Cams and Followers is fairly universal. The advice is usually to not let the engine run under 2000 or 2500 RPM for 20 to 30 minutes. This is only to ensure there's enough oil being drenched on to the cam lobes and followers until these fresh ground parts warm up enough, along with the oil, for these surfaces to start to absorb the oil and take some in.
This is ONLY a very very simple summery of all this and hopefully it will shed some light.
